HELP...What is connected to this metal tube?
Old Jun 5, 2008 | 09:35 PM
99fivespd's Avatar
PIcture is shot from drivers side staring between the air filter box and the brake system. Is it terminated or does it go somewhere?
Old Jun 5, 2008 | 10:01 PM
tyler5619's Avatar
freon? iuno, maybe someone else?
Old Jun 5, 2008 | 10:04 PM
black_maxed95's Avatar
is that the vacuum tube that connects to the mid pipe of your airbox? or is that the tube right next to it? either way its for a vacuum. turn your car on and put your finger near it to see if you can feel a vacuum.
^^^definately not freon
Old Jun 5, 2008 | 10:20 PM
99fivespd's Avatar
freon?? someone else???
MAybe its The ZOhlhan...
Old Jun 5, 2008 | 10:22 PM
snowboi1289's Avatar
I'm pretty sure I got the same tube with no connection.I'll look into it in the morning.
Old Jun 5, 2008 | 10:32 PM
nismology's Avatar
I <3 the 4th gen section.
Old Jun 6, 2008 | 04:53 AM
Turbobink's Avatar
I'm pretty sure this is just an open line... as I recall it's a tranny vent tube.
I've got the very same open line.
Old Jun 6, 2008 | 09:39 AM
tyler5619's Avatar
gawd it was just a guess. nobody else was replying, i was trying to give him a bump lol
Old Jun 6, 2008 | 02:12 PM
choray911's Avatar
The Crazy Azz Cracka
That is part of the vacuum network for the EVAP system that slowly allows the fumes from the gas tank to be released into the motor rather that the atmosphere. If you look at the right side of the front head, you should see the other side of the vacuum system as it passes under the intake tube. There you should see a bank of sylnoids that have vacuum connections. This is where it introduces them into the manifold. On a 99 CALI spec I have no idea where it would go. It would be different from my 96.
Old Jun 6, 2008 | 05:56 PM
99fivespd's Avatar
i got a 99 fed -spec. Ill look at the head
Fbana41
Aug 29, 2016 12:18 PM
Sep 27, 2015 08:37 AM
zmcneely13
Sep 26, 2015 02:26 PM
