NEW AXLES NEED ALIGNMENT AFTER???
Old Jun 11, 2008 | 08:32 PM
95maxdvt
I put new axles in the other day and clicking is definitely gone and it feels much tighter but car seems to have this shake when turning wheels either way and accelerating??
Possible Toe could change?
i removed shock bolts not balljoints.
Old Jun 11, 2008 | 08:34 PM
EnervinE's Avatar
i has college
You messed with your suspension, thereby requiring an alignment.
Old Jun 11, 2008 | 08:36 PM
95maxdvt
$90 just for front end and just had it done after inner tie rods WTF
any do it yourself suggestions lol, also dont wanna pay for it and have it not solve my shaking issues.
Old Jun 11, 2008 | 08:38 PM
EnervinE's Avatar
i has college
$90 is highway robbery. You can find a shop that will do the whole front end for $50, just look around.
Old Jun 11, 2008 | 08:41 PM
95maxdvt
Not VT lol 2 shops in town with alignment machines lol $120 for 4 wheel.
Wassick Tire, Midas
You ever seen a thrown alignment cause wheel shake??
isnt tires cause wasnt til after axles and there not cheap remans so not that either?????
Driving me nuts spent days on axles because of that stupid *** c clip getting stuck and then it fell in the trans so i had to pull gear selector plug and fish with a magnet for a day. Now its back together and shaking Arghh, was a lil shaky after i replaced passenger axle a few days b4 but now its worse after replacing drivers.
Old Jun 11, 2008 | 09:03 PM
QNO_A32's Avatar
i cant see a bad alignment causing a wheel shake. you messed with the suspension you need an alignment.the shake could be a cheap axle. but try and get the wheels balanced first.
Old Jun 11, 2008 | 09:12 PM
95maxdvt
NEW not remans w/ 70,000 mile warranty
new tires balanced.
idk these cars seem touchy though especially when lowered when i had new inner tie rods put it in it shook pretty bad til i got it aligned but i cant remember if it was similar didnt seem as bad.
Old Jun 21, 2008 | 12:54 PM
ng126's Avatar
Any work involving the suspension should be followed up by an alignment. $90 seems high for just the front, I'd check around.
Old Jun 21, 2008 | 01:34 PM
vilmaxima's Avatar
U SHOULD get an alignment first, If u take the lower two bolts of the suspension, it will in most cases throw u off alignment, unless u are not lowered u might be able to get away with it. But yes unaligned wheels can cause shaking. The back cant be adjusted for alignment anyways so u should NOT get charged for a 4 wheel alignment, cause they only do the front, they might hook the machine up to the back too, but theres nothing they can do to it except rip u off.
Old Jun 21, 2008 | 01:42 PM
Bird1411's Avatar
alignment is the way to go
Old Jun 21, 2008 | 02:58 PM
Sounbwoy's Avatar
All he did was replace axles. I just did the same thing, and I have no issues. Make sure everything's secure and that you didn't miss anything, first.
Old Jun 21, 2008 | 04:03 PM
mtrai760's Avatar
'Trynna' is not a word
You STILL need an alignment. Being off by 1 degree may not feel a whole lot different, but it sure will make your tires wear faster, and will affect the handling of the car. You cannot eyeball it.
Old Jun 21, 2008 | 04:40 PM
QNO_A32's Avatar
^^right you might not "feel" 1 deg. of camber but it will chew up your tires and well ,one degree of toe is another story. +1
Old Jun 21, 2008 | 04:51 PM
Hexon's Avatar
I just replaced my axles as well. I don't notice any difference, but I'm lowering my car within the next couple weeks. Till then, I'll wait for the alignment
Old Jun 21, 2008 | 05:12 PM
crewchief264's Avatar
Axles
I would say your fine without doing an alignment if everything was recently done. if yhou havnt had an alignment for awhile I would get one done.
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
ivorton23
Sep 26, 2015 09:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
