Head cracked??
Old Jun 13, 2008 | 07:32 AM
one_fast_max's Avatar
Head cracked??
hey guys...
ok i'm a little nervous at the moment. last night i finished taking apart the engine for my 00vi swap. i took the LIM off and looked in the intake ports on the head. 2 of the intake ports had coolant on 1 of the valves. the right one to be specific. This is the rear bank also. There wasn't a lot of coolant but it was obvious that it was coolant.
so what i'm wondering is how in the world did coolant get ON TOP of the valve.... do you think the head is cracked? i've never overheated or noticed coolant leaking....is it possible for coolant to some how get into the intake while undoing any coolant lines or anything? the port by the EGR looked wet but i didn't know if it was coolant or not...
again i've never had a problem with driveability or anything....
Old Jun 13, 2008 | 11:12 AM
bump....
Old Jun 13, 2008 | 11:56 AM
clive's Avatar
100% chingon
Originally Posted by one_fast_max
hey guys...
Have you noticed the coolant level dropping when using the car normally? Had to top up the coolant level more frequently then usual? I am using my car in temperatures averaging 34C which is pretty warm and I only need to add coolant every few weeks, what has your coolant consumption looked like?
I'd need a drawing of the head internals to say where the coolant came from.
Old Jun 13, 2008 | 02:44 PM
f550maranello2's Avatar
coolant runs through the inake manifold does it?
Old Jun 13, 2008 | 03:45 PM
Snypa's Avatar
manifold gasket failure.?
Old Jun 13, 2008 | 03:50 PM
well my coolant has stayed the same since i've had the car. i've had it now for a year and a half and i've never put coolant in it. never. and its filled up becuase i've checked it.
well i know coolant runs through the throttle body and in the rear by the EGR...but i'm confused how coolant would get ON TOP of the intake valve....
maybe just coincidental? 4 of the cylinders looked great....but two beside eachother had a little coolant....
Old Jun 13, 2008 | 05:53 PM
alset2's Avatar
this sounds like the logical answer. when you removed the intake coolant dripped in the intake port.to support this you said the coolant level never went down ,and trust me, if your car was burning coolant ,you would be aware of it
Old Jun 13, 2008 | 06:41 PM
well ok...i just didn't see how it would leak into the intake.
but you are right....if it was messed up i would know!
Old Jun 13, 2008 | 07:42 PM
93altima's Avatar
Turbo 4th Gen
Not to scare you but i just removed my dek LIM to get it cleaned and remove the swirl valves(i was to lazy to remove the while i was doing the swap) and i didnt notice any signs of coolant, but i could just be coincidental
Old Jun 13, 2008 | 08:13 PM
modenaf1's Avatar
Coolant runs through the intake manifold? That might explain why the intake is so hot on these cars....
Old Jun 14, 2008 | 02:30 AM
alset2's Avatar
one more thing ,almost every time I have seen a head crack so that it leaks coolant, its always in the combustion chamber part of the head.
...actually i will commit to saying "everytime", that is the case.
Old Jun 14, 2008 | 07:00 AM
pmohr's Avatar
No more Maximas...
Through the throttle body (like most other cars) and around the EGR port on the back.
What do you think this is, a 3800?
Old Jun 14, 2008 | 11:31 AM
Product_Of_Korea's Avatar
if anything try bypassing the coolant going into the tb. maybe its cracked in the tb???? just a thought
Old Jun 14, 2008 | 08:38 PM
Snypa's Avatar
Old Jun 15, 2008 | 09:29 AM
93altima's Avatar
Turbo 4th Gen
^^^^Thats the Pontiac motor right they are CRAP!!!
Old Jun 15, 2008 | 03:24 PM
yeah i was thinking about trying to get all the lines hooked up then putting pressure to the system and seeing if coolant leaks anywhere.....i'm just hoping it "somehow"...haha....got there because i haven't noticed any signs of cracked head or anything....
Old Jun 19, 2008 | 11:36 AM
clive's Avatar
100% chingon
Frankly, if coolant was getting into one or more cylinders you would probably be experiencing the nasty signs of fluid lock. (Water cannot be compressed). When coolant gets into a cylinder, usually you find that when the engine cools down, coolant gets in, then when you try to start it, it seems like the battery is flat because the engine resists turning over (because one or more pistons are trying to compress the unwanted fluid in the cylinder).
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
Andy29
Sep 29, 2015 05:32 AM
