98' 5MT Overheating.....Highway Only?????
Old Jun 14, 2008 | 02:45 PM
QNO_A32's Avatar
Any opinions on what to do first? Im thinking flush coolant system and new t-stat. Anybody else had this problem on the highway only? Around town it fine, it only does it when im on the highway at or above 3k in fifth for a while. Ill have to blast the heat and slow down for a while. Any help appreciated.
Old Jun 14, 2008 | 02:53 PM
alset2's Avatar
the coolant flush is a good idea, usally with the symptom you are having its the radiator not working . like if its clogged up inside and/or the cooling fins are blocked off with dirt or something to that effect.
Old Jun 14, 2008 | 04:08 PM
fat_kid's Avatar
could be the thermostat
Old Jun 14, 2008 | 04:18 PM
93altima's Avatar
Turbo 4th Gen
check to see if your fans turn on after the cars warmed up
Old Jun 14, 2008 | 04:27 PM
qnpark8282's Avatar
whats a fan got to with highway driving????? The fan is there to pull in air when the car is NOT in motion. check the t-stat.
Old Jun 14, 2008 | 04:34 PM
JtzMax's Avatar
Whatchyou say?
He didn't say, check the fans on the hi-way .... he said after the car is warm.
It could be a sticking thermostat as well .... flush the system, see if that helps. If it doesn't, then I'd look at the thermostat / water pump. If it turns out to be the water pump at all .... do the TC tensioner while you are at it.
Old Jun 14, 2008 | 06:22 PM
QNO_A32's Avatar
thanks for the info guys. oh man, I hope its not the pump.... The fans are running, but im pretty sure even if they werent in the car it wouldnt overheat on the highway. could I get away with just flushing the radiator? Im going to do the flush and thermostat same time i guess. any other suggestions/advice is welcome...................
Old Jun 14, 2008 | 06:32 PM
alset2's Avatar
only other thing I can think of is to inspect the cooling fins and make sure the are not clogged up. I have seen everything from mud,to bugs block airflow through the radiator...of course there is a condensor in front of it...hmmm...so check that too.
Old Jun 14, 2008 | 09:46 PM
arrocha87's Avatar
uhm wat bout the other way around. wat if the car runs great on the highway.. 80 miles each way but as soon as u get off it overheats? and the fans are running? not mine. mines running great *knock on wood* but a co worker has a 97 gle ands too lazy to sign up for the org.
Old Jun 14, 2008 | 10:48 PM
JtzMax's Avatar
Whatchyou say?
If they are too lazy, they get no help! Silence to the non-.org'rs ....
No really .... I'd say thermostat on that one mate.
Old Jul 28, 2008 | 06:08 PM
QNO_A32's Avatar
UPDATE: i did the coolant flush and changed the t-stat. the car is real happy crising at 70 now.... thanks for the help org!!!
bumpypickle
Sep 20, 2015 08:22 AM
BigLou93SE
Aug 30, 2007 01:42 PM
SteVTEC
Dyno Discussion and Slips
Feb 18, 2003 06:54 PM
