rear brake light woes
Old Jun 26, 2008 | 12:11 AM
cefiro8701's Avatar
my rear pass brake light works fine during the day...
...they even come on when i turn on the headlights...
...the problem lies when i step on my brakes, the rear pass brake light turns on instead of becoming brighter...
...i've been through 2 sets of 1157 bulbs..any idea fellas?
Old Jun 26, 2008 | 07:08 AM
97SEdriver's Avatar
this place is dead
you're not explaining something correctly.
if the rear passenger light is off...then comes ON when you press the brakes, it sounds like the brake light comes on, but the normal light is OFF?
more details are needed here
Old Jun 26, 2008 | 07:24 AM
internetautomar's Avatar
mod or sell?
Sounds like a bad ground
Old Jun 26, 2008 | 11:20 AM
Kazoo's Avatar
I had this problem lately. Check the ground wires going into the connectors by the lights. I had a ground wire back out on one of the connectors so the light had a floating ground. It worked fine until I stepped on the brakes at night. Then the backup lights lit up instead of the brake lights. So just make sure everything has a good connection.
John
Old Jun 26, 2008 | 10:32 PM
cefiro8701's Avatar
sorry what i mean to say was...
the rear passenger tail light turns OFF when i step on the brake...
the correct event should have the tail light becoming brighter...
i'll check out the wires tommorow...
hopefully i won't have to go the stealership for the parts as they can be butt monkeys when it comes to pricing.
Old Jun 27, 2008 | 02:12 PM
cefiro8701's Avatar
well...it wasn't the ground...
any other ideas?should i replace the socket? 50$ at the stealership for it...
Old Jun 28, 2008 | 03:57 PM
njmaxseltd's Avatar
Check all connections and sockets for corrosion and make sure you are using the correct bulbs in the sockets.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
