Replacing engine
Old Jun 26, 2008 | 10:38 AM
Abimax95's Avatar
Replacing engine
Hi guys I'm getting a used engine with between 80,000 to 120,000 miles my question is I found a couple from a 98 I30 for a really good price my question is will it bolt on to my 95 maxima like are all the plugs the same or there will be sensors on the I30 that my max will not have I just want to drop it in start it and do a burn out ha ha but really I don't want to be figuring out that the I30 has more or less or even different plugs does anybody has drop a I30 engine on there max and will it have more HP than a max i know that both cars are practicaly the same just different accesories but being Infinity will it have more HP and deifferent plugs ?? any input will be appreciated ..
thanks
Old Jun 26, 2008 | 10:47 AM
pmohr's Avatar
No more Maximas...
Same exact engine. As with any other engine swap, a difference in either emissions spec or year (hell, sometimes even production date of the same exact type of car) will mean you have to swap over your original components.
Likely this will be limited to emissions components, but there may be other stuff that requires a switchover.
If you keep the same ECU and swap over everything you need from yours, it should be exactly the same as your old engine was. No 'more HP' or 'different plugs'.
Old Jun 26, 2008 | 01:03 PM
Abimax95's Avatar
Thanks PMOHR I figure that but I wasn't sure ..
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
scarletsosa
Aug 17, 2015 09:09 PM
