question about an intake install on 95 maixma
Old Jul 1, 2008 | 08:12 PM
19max95's Avatar
I recently bought this intake from ebay (please dont flame me, i just got it for the sound)
http://cgi.ebay.com/ebaymotors/ws/eB...m=320267591099
I pretty much have a good general idea on how to install it but only have 1 concern. I know there are 2 sensors: one is on the maf and the other is inside the stock airbox...
Well, i cant seem to figure out where to put that air sensor ( the one inside the stock air box) in an intake... does anyone know?
Any help would be appreciated, thanx
Old Jul 1, 2008 | 08:24 PM
bigpulve+'s Avatar
Put it in the filter where you put it onto the pipe.....works fine for me...
curiosul's Avatar
on my other car, the sensor was sewn (don't laugh!) on the inside of the filter; the cable was "strangled" between the filter's "collar" and the intake tubing
I hope this helps!
Old Jul 1, 2008 | 08:38 PM
hornepirate's Avatar
i just fixed this problem...ive got a 95 maxima
i took the air temp sensor and kept the bottom of the air box on my car and have it bolted onto that. seems to be the best thing hope i helped.
btw if you dont wanna ghetto it the car will run fine with out the sensor your engine light will just be on
Old Jul 1, 2008 | 09:19 PM
maximase86's Avatar
I love lamp.
Worst case scenario, drill a hole and mount the IAT in the piping between the filter and the MAF. If you do it between the MAF and the TB, you'll need to devise a way to create a seal around the sensor. A much better option than what was suggested before.
Driving with your CEL, when you can actually easily prevent it from coming on is retarded.
S
Old Jul 1, 2008 | 09:36 PM
19max95's Avatar
actually, i once did it, and the check engine was on and my temp gauge in the car stopped working... so the gauge was showing that the car was cold even if its warmed up
Old Jul 1, 2008 | 09:37 PM
19max95's Avatar
S
thanx, but if i start drilling i mess it up... i'll probably stuff it in the filter somehow...
Old Jul 1, 2008 | 09:39 PM
19max95's Avatar
i'll probably try that
mowgli29's Avatar
Horizontally opposed.
Fawk the IAT sensor because it doesn't affect anything. Let it dangle or tuck it away somewhere.
While viewing data on a Nissan Consult II, timing was not affected even when the IAT temp went from around 40F to over 110F.
Old Jul 1, 2008 | 09:41 PM
19max95's Avatar
I hope this helps!
nothing funny about that, thanx for the advice
19max95's Avatar
lol, Fawk it indeed
Old Jul 1, 2008 | 09:43 PM
Snypa's Avatar
bore a hole in the cupler with screwdriver if you use any and force it in there,dont make a big hole now.
Old Jul 1, 2008 | 09:46 PM
93altima's Avatar
Turbo 4th Gen
i let mines hang
95Maxi
Aug 29, 2015 09:38 PM
98nismomax
Aug 26, 2015 03:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
