Wiring a Volt Meter
Old Jul 9, 2008 | 09:02 AM
matty's Avatar
Wiring a Volt Meter
I know its been done on here, where am I wiring it to ??
-matt
Old Jul 9, 2008 | 09:10 AM
black_maxed95's Avatar
dont you just do a positve and a negative? My radar detector reads the voltage and it just plugs into the cig lighter.
Old Jul 9, 2008 | 09:15 AM
matty's Avatar
I guess just wire it to a switched 12V source
Old Jul 9, 2008 | 10:17 AM
RacerX1320's Avatar
Black_Maxed<----what are typical volts your reading around town? With your radio on or headlights on etc? Sometimes at lights my volts dip all the way to 13.0 volts.
Old Jul 9, 2008 | 04:17 PM
MOHFpro90's Avatar
Matty, yes, just wire it to any 12V source. You could run it straight from the battery if you really wanna get picky about it.
Old Jul 9, 2008 | 04:22 PM
Well I have an UDP so Im gonna be lower than normal. I usually have 13.6-13.8 at normal driving. It dips down to about 13.2 at times when stopped. Usually it never gets lower than 13.6 tho even when stopped.
13.0 is pretty low if you have the stock pulley. If you are getting around 14 tho when driving I would say its not a big deal.
Old Jul 9, 2008 | 04:34 PM
fat_kid's Avatar
i know this is a 5th gen, but it may help
http://forums.maxima.org/5th-generat...tallation.html
Old Jul 9, 2008 | 05:50 PM
matty's Avatar
Well if I did that, would it drain over night since its constant juice going to the meter, or it doesnt draw anything ??
-matt
Old Jul 9, 2008 | 05:54 PM
pmohr's Avatar
No more Maximas...
-matt
It does draw some, but not an amazingly large amount (you're only really running a primitive circuit and an LCD, after all). Hardly enough to drain the battery overnight.
Old Jul 9, 2008 | 06:11 PM
99Silvermist SE's Avatar
Wire it to your Cig lighter. All you need is any power source in the car. The cig lighter is the easiest IMO plus if you run it of the Cig lighter you dont have to worry about draining the battery.
I'm not sure why some of your cars are running at 13+ volts. They should be running around 12 to 12.8 since its a 12 volt power source.
Old Jul 9, 2008 | 06:25 PM
pmohr's Avatar
No more Maximas...
You are aware that most alternators output anywhere from 13 to 14 volts (or more), right?
It's a 12 volt battery, but with the alternator charging it's higher than that.
alset2's Avatar
well actually the battery is 12 volt ,but the system operates at about 13-16 volts. this way the car has enough power to run everything and also to keep the battery charged.
i agree with the above post ,13 is a little low but if it comes up when you engine gets some revs its probably no big deal....yet.
Old Jul 9, 2008 | 06:37 PM
DrTySOUFMaX23's Avatar
http://glowshift.com/pdfinstructions/t7b7w7/VOLT.pdf
Old Jul 10, 2008 | 04:44 PM
vilmaxima's Avatar
I just wired mine to positive battery and a ground that is close to the meter, mine does not have a light tho.
Old Jul 10, 2008 | 08:57 PM
MOHFpro90's Avatar
-matt
Exactly what pmohr said. There is virtually no draw from it. Hell, you probably drain more by leaving your lights on for a few seconds after you turn off your car.
Old Jul 11, 2008 | 06:40 PM
JtzMax's Avatar
Whatchyou say?
Pmohr .... lol
I guess you don't realize that Pmohr is cert'd in most everything Maxima. I run a cap on my system and at idle, I read 14.2v no amps on, no radio, no lights, no fan, no wipers. With lights on (I run a pair of HID ballasts) I read 14.4v. Just my thoughts but seems typical v = 14. somethin.
Matty ... if you run a pos lead to the meter from an acc lead, it will not drain and turn off when you turn the key off.
Old Jul 11, 2008 | 06:43 PM
pmohr's Avatar
No more Maximas...
Originally Posted by JtzMax
Pmohr .... lol
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
