Fault codes!
Old Jul 14, 2008 | 01:30 PM
Jamaha80
Fault codes!
P0500 -- Vehicle Speed Sensor
I already replaced it a couple years ago when I had the same fault code.... I remember the code coming back immediately after I replaced the part, and just forgetting about it.
P0120 -- Throttle Position Sensor A circuit malfunction
I tested this part today as a culprit for idle/driveability issues and determined it's bad
P0400 -- EGR Flow Malfunction
I guess I should clean it. I wonder if doing a hardcore seafoam treatment a while back had anything to do with this...?
P1705 __ Manufacturer Conrtl Transmission
No clue, but my OD OFF light flashes when I start the car. Sometimes it seems impossible to get the tq converter to unlock/downshift, shifts seem unexpected, etc. I'm hoping that has to do with the TPS, but it may not.
I cleared them and will see what comes back, and go from there. I'm pretty positive I'll be needing a TPS, and I'm wondering if the 1st and last one are related somehow?
My speedo is also real flakey. It works most of the time though. I'm guessing thats just a bad cluster unit itself and doesn't have anything to do with the VSS as I originally thought.... Your thoughts?
Old Jul 14, 2008 | 10:09 PM
oldngivout's Avatar
Willing to learn
P0500 - your speedo is bad. Doesn't make much sense but it's true.
Old Jul 14, 2008 | 10:19 PM
Jamaha80
Yeah. My neighbor is a technician for Infinity. He agrees. Is that a code that triggers a CEL?
I've had the cluster out before, tried tightening some screws, but it didn't help. It's not that high on the to-do list anyways.
Old Jul 15, 2008 | 06:34 AM
NmexMAX's Avatar
dot dot dot ...
Did you mean Infiniti?
Old Jul 15, 2008 | 08:41 AM
Jamaha80
Obviously. Thanks for your input on the situation.
Old Jul 15, 2008 | 03:15 PM
vilmaxima's Avatar
How many times does your o/d light flash? Are they the same flashes?
Old Jul 15, 2008 | 03:25 PM
Jamaha80
When I turn the key to ON, the OD light comes on solid for about 3 seconds, then flashes either 15 or 16 times. I tried to check again, but I cant get it flash anymore.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
