check engine light IACV related
Old Jul 20, 2008 | 01:44 PM
sergiovv's Avatar
few weeks ago i had 3 codes which two of them have been fixed they were knock sensor wich a bought at ebay and replaced my self (thanks to this forum where a learned how to doit) and the MAF sensor which i also just cleaned it (thanks again to this forum)
then i cleaned the IACV and now i only get 1 code (05 05) the guy at autozone gave a list that he did print out of the pc and this is what the list said:
definition:
IAC circuit condition or idle speed higher / lower than expected
explanation:
the ECM has detected that the IAC counts are higheror lower than expected. the engine is not in its expected range.
probable causes
1-vacuum leak on engine
2-dirty throttle body
3-IAC motor defective
4-poor electrical connection to the IAC valve
i already cleaned the throttle body and the IACV also checked for any vacuum leaks.
but the light its still on and i already reset it like 3 times
inspection got to be done and i am afraid is not going to pass.
does anyone knows what else to do i how to get rid of the engine light just to pass the inpesction..??
thanks!!!
Old Jul 20, 2008 | 06:54 PM
knight71's Avatar
definition:
explanation:
probable causes
thanks!!!
0505 means no problem detected, so that's a good thing: As far as getting rid of the cel. I'm too sure. Maybe someone else wanna chime in..
Old Jul 20, 2008 | 08:01 PM
lexoid's Avatar
definition:
That's a definition of the OBDII P0505 Code wich is IACV. As was said earlier, 55 means no problem were detected. In the FSM you would find all OBD and related Nissan codes
Old Jul 20, 2008 | 09:39 PM
pmohr's Avatar
No more Maximas...
Nissan really should've used a different numbering scheme to prevent confusion with OBD-II codes (like the 5.5s).
In any case, OP: did you check the codes manually, or with a scanner?
Old Jul 21, 2008 | 04:07 PM
sergiovv's Avatar
the guy at autozone did check it with that device they have
then i did reset the computer by turning that little screw by the gas pedal and after that the light went off but as soon as i start going oout of the parking lot the light came back..........
Old Jul 21, 2008 | 07:51 PM
lexoid's Avatar
Before reseting the "Check Engine" light, what code it was blinking out? Was it 25 (IACV)?
I had a bad IACV for a while, but got 25 error code only once. Turned out my IACV had a bad winding. If you are getting the same code (nissan code 25), then check your IACV. Look into FSM for more details, but generaly, there's a 6 pin connector on the IACV. Measure resistance from from the row's central pin to the row's outer pins and it should be around 29 ohms
Old Jul 21, 2008 | 08:33 PM
sergiovv's Avatar
i saw the blinks but didn't count them ... but i 'll do that as soon as i got out of work tomorrow... thank you men.
Old Jul 22, 2008 | 03:50 PM
sergiovv's Avatar
i just checked the blinks and its 2 long blinks and 5 short blinks so i guess you were right but now what do mean by "FMS" and did you replace the IACV when you did get the code??
Old Jul 22, 2008 | 04:53 PM
pmohr's Avatar
No more Maximas...
FSM, not FMS.
See sig.
Old Jul 22, 2008 | 07:42 PM
lexoid's Avatar
FSM stands for Factory Service Manual. Check Pmohr's profile. You'll find a lot more details on IACV troubleshooting in FSM
I've replaced mine, because one of four windings was fried, displayed 150 kOhms instead of 30 Ohms. It should be possible to replace windings without removing IACV assembly, but it may be worth to remove it just to clean IACV if it never was done before. Just get a IACV gasket beforehand. Shouldn't be too expensive.
Old Jul 22, 2008 | 08:51 PM
nafddur's Avatar
I too replaced my IACV after I started regularly getting the 25 code. The new valve from the dealer was about $180, and the gasket was a few dollars more.
After getting the old valve out and seeing the carbon build up inside, I realized that just a cleaning (along with reinstalling with the new gasket, of course) was probably all that was needed.
But since I had already bought the new valve, I just went ahead and installed it. No more code 25's.
Old Jul 23, 2008 | 07:31 AM
sergiovv's Avatar
WOW !! i am impressed about how much information does the FSM (Factory Service Manual) has and how it explains everthing that could be wrong ,.......i am gonna do all of the trouble diagnosis.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
