HOW TO- 5.5 Gen Front Brakes on 4th Gen
I wanted bigger brakes, but I didnt want to spend a fortune (as much as one would spend, say for a Z32 upgrade, or the 6th gen rotors with Z32 calipers, etc...) for just front brakes. Plus I dont autoX, I just do alot of highway spirited driving; so I wanted a beefier setup that wouldnt break the bank.
COST-
Calipers and caliper mounting brackets used- $100
RPT plated/ X-Drilled Rotors, Axxis Metal Master Pads, 2 liters of ATE Blue Racing Fluid- $185shipped
Ubber Drill Bit- $35
Bolts and lockwashers- ~$10
SPECS-(per 1995 FSM and 2003 FSM)
4th gen Rotors (mm/ inches)
280x22/ 11.02x0.87
5.5 gen Rotors (mm/ inches)
296x24/ 11.65x0.94
4th gen Caliper Pot (mm/ inches)
57.2/ 2.252
5.5 gen Caliper Pot (mm/ inches)
57.2/ 2.252
HOW TO- (I write this assuming you already know how to do a brake job, this how to made with attention to the work specifically related to the conversion process of being able to install these bigger brakes)-
* Remove wheels, calipers (disconnect the lines from them but have a bottle near, they will leak alot of fluid), caliper mounting brackets and pads
* Have this ubber drill bit...
It cost me $35 locally at a "nothing but nuts and bolts- specialized hardware store (Mitchell Supply Company)
also 4 of these Metric bolts with lock washers (stock 4th gen on left, new 5.5gen on right)...
I bought them so long ago I dont recall the specs, so just go to the hardware store with the caliper mounting bracket for thme to check
* With the Ubber drill bit, drill out the two holes on the hub. Try your best to keep it straight. Go slow with the bit at first because if it gets caught up, the drill WILL fling around and it could cause bodily harm depending of how strong of a drill you have. Once it started boring the hole out just go downtown on them. They should look like this afterwards...
* Make a few cuts along the shield's overlap up to the vertical part and with pliers bend the overlap up to vertical. The 5.5gen rotors wont fit otherwise...
* Now with that done, the installation is the exact same as a normal brake job, only that you're using the 5.5 gen parts. Hook up the lines and you will have to bleed ALL 4 calipers. At least with me, I let so much fluid drain that air got into the master cylinder, thus my line for the rear brakes had air, so I had to bleed all 4 corners. Break them in and enjoy the noticeably improved braking over that of the 4th gen parts :-D
COST-
280x22/ 11.02x0.87
296x24/ 11.65x0.94
57.2/ 2.252
57.2/ 2.252
Well in all honestly, my old brakes were worn to hell. Pads on the passenger side had about 2mm of material left. Almost down to the metal backing. So yes its definitely worlds better. However, I DO remember what these brakes felt like 3 yrs ago whenI changed them, and yes, these 5.5gen brakes ARE noticeably stronger as far as initial bite and just orerall braking power. Its like adding a turbo to the engine... but to the brakes, LOL. The second time I slammed them from 80 on the highway during the break-in, car felt like it was going to flip forward, lol.
Nope, those are blown 6yo+ AGXs lol. Coilovers are not worth the cost for MY uses.
cool job, good to see something new. But Im wondering about the difference in brake power. The specs show that the 5.5 and 4th gen calipers are the exact same. Wouldnt that mean the braking is the same? Are the 5.5 pads bigger? If not its the same surface area contact and brake pressure, right?
**** I added a cost breakdown to the original thread****
ok I understand where the braking power comes from. I wasnt sure if the pads were bigger on a 5.5 and I didnt think about the larger torque. I agree, definately a great bang for the buck. Great alternative for those that dont want/need a bbk.
so, with the whole drill bit thing... would a stepped bit be good to use to get it started (1 step deep) and then finish it off with a straight bit?
seriously- and I'll give all the credit to the bit's construction, you dont need a step bit at all. This particular bit cut through the iron hub like butter. Just go slow at first. Once you're about 1mm into it, it wont skip around so you can just push it right through no problem
go for it
not off the wall just teh q45/j30 need a wider rotor. I cant say ya or nay for sure but I know those calipers dont bolt up to stock 4g rotors etc, which is why we needed to buy Jeffs brackets
YES! I've been waiting/wondering why no-one has done this!! AWESOME!
Also, a little tip, you can avoid having to bleed all 4 by very lightly pinching the line with visegrips until you are ready to install and bleed.
http://forums.maxima.org/advanced-su...inch-rims.html
thank u
correct, these brakes will clear MOST 16" wheels.
Base 5.5's came with 16's. GLE/SE came with 17's.
If it clears the 5.5 gens 16x6.5's then i dont see why it wouldnt clear the 4th gens 16x6.5's because i believe they are the same offset and similar spoke design.
Anyhow, i guess this would be between stock and Q45's (stock, 5.5gen, 6th gen, q45, z32/r32, brembo/apracing).
Nice! Not only are these slightly more powerful due to the slightly larger diameter and larger pad, but I bet they absorb and dissipate heat better too!
My stock 4th gen brakes are quite wimpy. If I drive spirited on a mtn road, after hauling speed down hard on the brakes 6 or 7 times I can feel the stock brakes starting to fade already.
so not sure if i'm understanding this, but right now i have 4th gen knuckle, hub, and bearing. I picked up this stuff from the junk yard since i need a new hub and bearing on my 5TH GEN. What do I have to do to make this work on my 5th gen? just drill the 2 holes that hold the caliper on the knuckle of the 4th gen hub? OR what?
you should have just picked up 5.5 hubs.
