5spd swap, shifter hits up against heat shield. what to do?
Old Aug 5, 2008 | 06:13 PM
timmay5835's Avatar
Hey guys, I am just about done doing my 5 speed conversion, bolted in the support and control rods. But the shifter is rubbing up against the heat shield/exhaust, making it very difficult to shift into any gear. Should I just remove the heat shield? Or maybe dimple the heat shield to make some room for the shifter? Has anybody else ever had this problem? Sorry for the noob question but I searched and couldn't find anything. Any suggestions would help out a lot. Btw it is a short shifter also, idk if that could be the problem.
Tim
Old Aug 5, 2008 | 07:26 PM
Mr.Duck's Avatar
as long as everything is installed correctly, there is no harm in taking off the heat shield or dimpling it a bit, when i installed my STS it scraped a bit on the heat shield, so i just bent it so that i wouldnt hit anymore
Old Aug 5, 2008 | 07:32 PM
timmay5835's Avatar
ok, thanks for the help Mr.Duck., ill give that a try tommorow.
Old Aug 5, 2008 | 08:16 PM
f550maranello2's Avatar
i dunno man i removed the shield and the shifter gets toasty... i dont know if thats good or not
Old Aug 5, 2008 | 08:38 PM
mtrai760's Avatar
'Trynna' is not a word
I had the same problem when I did a 5spd swap on my old Maxima. I just took a dremel and cut out only where it was contacting. That way I still had the shield in place. Worked like a charm.
Old Aug 5, 2008 | 09:08 PM
JonBlz's Avatar
a.k.a. STuNtMAN
i had the same problem when i did my swap in 06 with the shifter hitting the heat shield wht i did waas took off the heat shield and banged it out a bit and no more hitting
Old Aug 6, 2008 | 09:52 AM
Heat shield isn't needed IMO, and is just extra weight. Ditch it. Ptatohed has removed his along the whole tunnel for about 1.5 years now with no ill side effects. Next time I'm under there, mine will be removed too.
Old Aug 6, 2008 | 11:34 AM
99BlackMaxMS's Avatar
I removed my heat shield when I did a STS as well, as it was rubbing and making an annoying vibrating noise. I noticed no differences without it. I wouldnt worry about running without one.
Old Aug 6, 2008 | 12:47 PM
timmay5835's Avatar
yeah, i just removed my heat shield, but the STS is still rubbing against the exhaust, but nearly not as bad. and i dont even have the rubber things attached to the exhaust.
Old Aug 6, 2008 | 03:13 PM
modenaf1's Avatar
Ooo I love the sound of weight reduction. How much can be lost by removing it down the entire tunnel?
Old Aug 6, 2008 | 04:19 PM
timmay5835's Avatar
ehhh not very much, maybe a couple pounds AT THE MOST.
Old Aug 6, 2008 | 04:26 PM
Blackwind's Avatar
still? that dont sound right. retrace your steps on all of your connections again. somewhere near the sfiter may not be set right.
Old Aug 6, 2008 | 04:40 PM
I forget, but it's in the 3-5 lbs range. Ptatohed and I keep all the weight we shed in an excel spreadsheet so we don't have to remember it. I can look it up and give you a definitive answer if you like.
True. But a pound there, a pound there starts to add up. Even with my SC and add-ons, I've managed to shed over 200 lbs.
Originally Posted by Blackwind
still? that don't sound right. retrace your steps on all of your connections again. somewhere near the shifter may not be set right.
Agreed.
Old Aug 6, 2008 | 05:00 PM
timmay5835's Avatar
ehhh, this has me confused, here are some pics, im pretty sure i have everything set right? correct me if not. i really think it has to do with the short shifter, because it is scraping at the bottom of the control rod. could it be that i have a stock exhaust? would upgrading to an apexi world sport fix this problem? i can still change gears fine but it scrapes when changing into some gears.
Old Aug 6, 2008 | 05:01 PM
timmay5835's Avatar
Nardi FTW!
Old Aug 6, 2008 | 06:14 PM
modenaf1's Avatar
Agreed.
Oh NICE! Sorry to side track this thread, but could I take a look at that spreadsheet? I want to do some serious weight reducing. So far the only thing I've done is take subwoofers out of the trunk, take the spare tire and jack out, and fill my gas between 1/3rd tank and 1/8th. If I could shed even as much as 100lbs of stuff that is kinda useless (like the heat sheilding for example) that would be so amazing.
Old Aug 6, 2008 | 06:42 PM
timmay5835's Avatar
so why don't you PM The Wizard and discuss with him there instead of here.
Old Aug 7, 2008 | 07:57 AM
Blackwind's Avatar
Nardi FTW!
you are missing a major piece!!! the pice that holds the shifter in place and keeps it at the right height.
Hole Bracket - 34560-70N00 go to your nearest dealer and take this number to confirm this is what you need. cause according to your pics its missing. look at the last one. i should not beable to see the ball of your shifter.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
ef9
Sep 10, 2015 10:35 PM
I<3 A32's
Sep 10, 2015 11:07 AM
