Factory Alarm and Intermittent wipers stopped working
Old Aug 6, 2008 | 05:54 PM
khantalha+'s Avatar
lets keep it short... came back from work and it was drizzling a lil bit so turned my wipers to intermittent, and they wont work, drop it down to the second position(normal speed) they are working, go to the third one(fast speed), they are working, go back to intermittent, nothing...
come home, get out of the car, tried to lock it with the remote... guess what...
remote wont do **** at all... security light stopped blinking too...already check all the fuses and everything looked good....any one have any idea what is goin on...
tnx
T
Old Aug 6, 2008 | 06:03 PM
internetautomar's Avatar
mod or sell?
pull out the fsm and trace the wiring diagram to the point where they have a connection in common, then find that connection in the car and trace back manually to the battery and somewhere along the way you will probably find a damaged wire
Old Aug 6, 2008 | 06:12 PM
Nopike's Avatar
Do clock and vanity (visor) lights work? If not fuse #40 7.5AMP is blown.
Is there anything else that is not working?
Both intermittent wiper operation and anti-theft system are controlled by the body control module something may be going on with that.
Old Aug 6, 2008 | 06:14 PM
Nopike's Avatar
Have you done any work on the electrical system lately? Does the car have any add-on or aftermarket wiring/electronics? Problem just started out of the blue?
Old Aug 6, 2008 | 06:21 PM
khantalha+'s Avatar
not all i got is mevi, rpm switch and etc...
Old Aug 6, 2008 | 06:22 PM
khantalha+'s Avatar
the both work..
Old Aug 6, 2008 | 06:24 PM
Nopike's Avatar
Check if anything else is out door locks, sunroof, trunk pop, audio, anything?
Old Aug 6, 2008 | 06:25 PM
vilmaxima's Avatar
my guess is bcm module, or a wire like stated above.
Old Aug 6, 2008 | 06:28 PM
khantalha+'s Avatar
everything working my friend
Old Aug 6, 2008 | 06:29 PM
Nopike's Avatar
Check fuse #19 7.5 Amp very closely remove it and look at it. That fuse is used for the theft and wiper circuits.
Old Aug 6, 2008 | 06:37 PM
Nopike's Avatar
Have you checked under hood fuses by battery, there is a 7.5Amp on there also a possibility. How are you checking fuses? Visually? If you are checking fuses with a fuse tester while the fuse is in the fuse holder? That is not reliable.
Old Aug 6, 2008 | 07:05 PM
khantalha+'s Avatar
yeah i check all the fuses under the hood, i am gonna do lil more hunting tomorrow and wil let u know whats goin on...
Old Aug 6, 2008 | 07:43 PM
vilmaxima's Avatar
have u done a swap from normal to intermittent? Your locks, and wipers are controlled by your BCM(just looked through the Haynes electrical).
Old Aug 7, 2008 | 03:22 AM
khantalha+'s Avatar
ok i ll check .. no my car is a se and it came with the interittent wipers
Old Aug 7, 2008 | 01:23 PM
vilmaxima's Avatar
Allright try fuse(these are for power locks 97-99, 95-96 is different) #40 7.5a, yel/blu wire from bcm to key switch, from key switch to fuse block its yel/blk(key switch) #12 7.5a pnk/grn from bcm to fuse block(IGN) Fuse #56 7.5a pnk from bcm to fusible link box(bat). For your wiper, fuse #19 7.5a, ppl from bcm to itermittent on the wiper stalk. I guess if all else fails, try to unplug it and plug it back in. If you need a new BCM, I got 2 for sale. I can check them to see if they work if you need one.
Old Aug 10, 2008 | 05:31 PM
khantalha+'s Avatar
i ll let you know tomorrow
Old Aug 11, 2008 | 06:35 PM
khantalha+'s Avatar
its fixed now i unplugged the bcm and let it sit for couple hours and plugged it back in and there it is my...everything working
just wanted to let you peeps know its working and thank you so much for the responses/help....i really appreciate it
Old Aug 11, 2008 | 06:38 PM
vilmaxima's Avatar
Glad to know. Good thing you didnt buy a new one. Sometimes thats all it takes is to unplug it and plug it back in, it resets it, and in your case it all worked out.
Old Aug 11, 2008 | 08:07 PM
khantalha+'s Avatar
yep
thanks for the help bro
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kenc15
Aug 5, 2015 08:29 AM
