98 Maxima Day-run light dead
Old Aug 9, 2008 | 08:25 AM
holymoly's Avatar
My day run lights I had the impression never burn out have.
I'm certain these are not the standard halogen lights that I manually turn on and have already replaced.
These lights are on constantly when the car is running.
What are the model and specs and where to purchase?
Old Aug 9, 2008 | 12:39 PM
Dave H.'s Avatar
I thought they were the high beams on a lower output??? But I may be wrong. You could check to see if your high beams work. Have you checked your fuses? I think there is a fuse for the DRL.
David
Old Aug 10, 2008 | 01:08 PM
holymoly's Avatar
There is no fuse for DRL.
I checked the Haines manual and nothing about the high beam/DRL lights,
and the high beams are working.
I went to Canadian Tire and the kid behind the counter didn't know.
Will check with dealer tomorrow.
Old Aug 10, 2008 | 03:17 PM
2da mizzax's Avatar
Check the FSM.
"The headlamp system for vehicles in Canada contains a daytime light unit. The uit activates the high beam headlamps at approximately half illumination whenever the engine is running...."
Just had to fake my DRLs for federal inspection.
Old Aug 11, 2008 | 05:24 AM
holymoly's Avatar
Called Nissan and its th Day Run Light Control Module on the right side in engine compartment.
$189. hmmm
Old Aug 11, 2008 | 04:47 PM
vilmaxima's Avatar
left side if you are looking at it from the front. Its a little black box right by the winshield res, there are two plugs going into it. Mine doesnt work either, but I like it better for it to be off during the day anyways. Grab one from a junkyard and save yourself well over $100. Heres a pic for reference:
Slamrod
Apr 10, 2016 05:24 PM
Balkins
Feb 1, 2016 12:45 AM
EuroDriver
Sep 14, 2015 06:08 PM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
