interior light problem (need help)
Old Aug 24, 2008 | 12:15 PM
9maximuz8's Avatar
hey guys,
i was changing my instrument panel light last night and the + - wires touched each other, then i heard a little tick noise from around the fuse box, then all the interior lights went out. now this has happened to me before but usually its the fuse which burns out, but this time its not that, i checked all the fuses in/out the car. everything works but the instrument panel lights, climate control lights and all that stuff. what could it be?
thanks in advance
Old Aug 24, 2008 | 12:26 PM
Maxima_Joe's Avatar
4th Gen Parts King
If the fuses are good you probably fried the dimmer switch.
Old Aug 24, 2008 | 04:46 PM
papo020's Avatar
That's a good one! Good luck with the fix. BTW that is a nice looking Max in your sig!
Old Aug 24, 2008 | 08:28 PM
9maximuz8's Avatar
thanks guys
does anyone have the wiring schematics?
Old Aug 25, 2008 | 07:09 AM
papo020's Avatar
Give me some time cause I'm not around right now; but I can see if the Haynes manual has the schematics. Unless someone else knows.
Old Aug 25, 2008 | 08:20 AM
Nopike's Avatar
Check fuse #18 (7.5Amp).
The fuse numbers are molded into the underdash fuse holder, you have to look very closely to see them. If dimmer switch is blown, as is possible, if you pull out the switch you will probably be able to see damage to the switch.
Old Aug 25, 2008 | 10:08 PM
9maximuz8's Avatar
ok i found the problem, it was the fuse. except the problem was when i checked it i didnt look close enough, there was a very very thin crack in it which i missed about 3 times. anyway thanks everyone
Old Jan 6, 2014 | 10:07 AM
KRDS's Avatar
Interior Dash Light on 98 maxima
to all This weekend, i replaced the radio on my 98 maxima and now my dash light is not working. I checked the #18 fuse it was blown, i replaced it and it blew up again. Any ideas ?
KRDS
Old Jan 6, 2014 | 11:47 AM
bewrong's Avatar
Double check that you wired the harness correctly.
Old Jan 7, 2014 | 09:35 AM
KRDS's Avatar
#18 fuse
bewrong -- which wires should i pat attention to ?
homeyclaus
Sep 3, 2015 06:15 PM
rbaker100
Aug 28, 2015 08:11 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
