Stripped bolt on LCA ball joint... Any ideas?
Old Aug 28, 2008 | 07:25 PM
B_Eaze's Avatar
I was changing my LCAs today, ran into a few stubborn bolts and broken tools but nothing too serious until i finish the passenger side and go to the driver side. ..
The ball joint nut isn't a castle nut, big deal right. .. I go to take it off w/ 3/4 open end wrench and feel it moving, but it was actually stripping. So i go to the other side of the hub to get at it from a different angle. When i started turning it it felt like the bolt was made of clay . So i get out my vice grips, mark a spot on the bolt so i can see how much it moves and get a good REALLY tight grip on it and take the 4 lb hammer and tap it, tapping it pretty lightly. It starts moving and i open the vice grips. .. Super stripped, like it was made outta puddy...
Should i get a hacksaw and go to town with it at the bottom of the nut? use a drill bit on it?? Or should i chaulk it up as a loss and take it to the shop and have them remove it ??
Old Aug 28, 2008 | 08:05 PM
internetautomar's Avatar
mod or sell?
I'd cut it.
Old Aug 28, 2008 | 11:50 PM
rm4628's Avatar
CLICK CLACK 1
I would use a cut off wheel, why work hard. Just dont go to deep and you should be fine.
Old Aug 29, 2008 | 07:11 AM
maximabebe's Avatar
Definitely. If ya have a grinder, cut it then replace the bolt. If not, then borrow one.
Old Aug 29, 2008 | 08:21 AM
B_Eaze's Avatar
Don't have a grinder, can i rent one from Home Depot? I'll go after work, i need to get some hacksaw blades anyways.
Old Aug 29, 2008 | 08:51 AM
barnone's Avatar
10 or 20 dollars will get you a cheap angle grinder. After you have it you'll wonder how you ever got along without it.
Old Aug 29, 2008 | 09:07 AM
B_Eaze's Avatar
....hmm, I'm gonna be working in my apartment complex parking lot and I'm already pushing the envelope with the other auto work i do. I'll see if I can hack it off first. Thanks
Old Aug 29, 2008 | 01:32 PM
njmaxseltd's Avatar
People, seriously, use the right tools!
Open end wrench, you must be kidding me....
Old Aug 29, 2008 | 06:14 PM
B_Eaze's Avatar
thanks for that bud. what should i have used? unless i removed the axle cant get a socket on there, right? I've searched and quite a few people use the same method i did. i changed the first one fine but the driver side one was changed a couple years back and the shop i had do it obviously pressed the ball joint out and pressed the new one in. Maybe tranny fluid deteriorated? either was my buddy has a grinder and im gonna get busy with it this weekend.
if have any suggestions of an easier i am very open for assistance, especially since i might be changing the bushings .... please
Old Aug 29, 2008 | 07:40 PM
QNO_A32's Avatar
>>>>> i cant see that even being the right size. LOL maybe a 19mm???
Old Aug 29, 2008 | 07:57 PM
B_Eaze's Avatar
u didnt read my first post, that ball joint was replaced at a shop when i first got my car, they musta thru on whatever ball joint they could find. my passenger side was a castle nut like its suppose to be, i think it was 7/8. that side went fine. i went to the driver side and my 7/8 was way bigger than the nut. i look at the nut ands Its an small, ugly rusted bolt.
Old Aug 29, 2008 | 08:57 PM
Cutler's Avatar
Total the car....
Old Aug 30, 2008 | 04:32 AM
B_Eaze's Avatar
Originally Posted by Cutler
Total the car....
... hopefully it doesn't come down to that
Old Aug 30, 2008 | 04:49 AM
j2b4osan's Avatar
I say if to don't have a grinder use a sawzall they are great. Just gets metal cutting blade and it'll cut through like butter . Most people have one if you don't I'm sure someone you know does. I've used them many times to remove stripped bolts befor I got a grinder. And I gotta say the sawzall was faster. Good luck
Old Aug 30, 2008 | 01:18 PM
Product_Of_Korea's Avatar
go to menards. buy the tool shop angle grinder as someone else suggested then return it
Old Aug 31, 2008 | 09:26 AM
B_Eaze's Avatar
got this from a friend...
I'll put it to work tomorrow
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
zmcneely13
Sep 26, 2015 02:26 PM
