Parasitic Drain-Help
Old Sep 21, 2008 | 07:57 PM
  #81
Nopike's Avatar
Congratulations, I figured you were close. it looks like your alarm is now working and the car is going into sleep mode. Some of the posters in this thread did say that 100 milliamps should not be enough to drain your battery, they may be right, only time will tell. I think that your drain problem will probably be solved. Post in a few days or a week or two when you are sure the drain problem is solved.
Old Sep 21, 2008 | 08:08 PM
  #82
matty's Avatar
Well you have to remember, this has been a problem over the past 5 years or so with I would say about 7 or so replacement battery's and recharging and jumping them maybe a hundred times. I have alot of research on these Optima's and once you drain them once, they never really rebound to full potential. Do that a few times and its shot. Thats why recently, the charge would only last about 12 hours on this battery.
-matt
Old Sep 21, 2008 | 08:12 PM
  #83
maximariceboi's Avatar
oh wow....sweet! congrats on your findings.
Old Sep 21, 2008 | 08:41 PM
  #84
Nopike's Avatar
If the problem is solved this will probably help some of the others with the same problem, especially if they know how to use a multimeter.
Old Sep 21, 2008 | 08:52 PM
  #85
Nopike's Avatar
-matt
Your sure are dedicated to your Maxima I would have thought about getting rid of the car after a dozen or so jumps, that does not sound like fun. Hopefully you will be enjoying you reliable Maxima from here on.
Old Sep 22, 2008 | 06:43 AM
  #86
JSMax's Avatar
Sold
I think it's awesome that a forum like this one can get together with members from all over north america and help out a person with his cars electrical problem.
Glad you were pointed in the right direction and was able to fix it. Imagine if you were on your own with this. Do you think you ever would have found it?
I didn't think that I would that's why I finally gave in and took mine into the dealership and had them find it for me.
Oh and 80-100 milliamps draw is acceptable for new cars with 7+ computers. For a car that is 10+ years old... that's enough to drain the battery over a few days.
Just so you know.
Old Sep 22, 2008 | 07:06 AM
  #87
choray911's Avatar
The Crazy Azz Cracka
I've had a revilation this weekend too. I left town for the weekend, and for the first time ever I armed the aftermarket alarm in my carport. Behold, this morning When I went to crank it up, she started. Do you guys have after market alarms, or are you running the factory alarm? I still need to hunt down the root of the problem.
Old Sep 22, 2008 | 07:46 AM
  #88
matty's Avatar
Just so you know.
I have to agree thats a good amount of draw, especially when I kept going through batteries about once a year, from recharging and draining, recharging and draining.
Do the parasitic drain test and see what number your at after the car goes into sleep (pushing down the hood button, all doors locked, trunk closed)
After you get that number youll have a better idea where your at.
Old Sep 22, 2008 | 09:55 AM
  #89
JSMax's Avatar
Sold
I have an aftermarket alarm system that like most it is tied into the factory system. I personally have not used my factory keyfob in more than 4 years. I have had this drain for about 6 months before I took it in. Like I sated in my eariler posting... the clowns at the body shop were to blame for my troubles.
Old Sep 22, 2008 | 02:24 PM
  #90
matty's Avatar
Just to make this clear, this switch has NOTHING to do with the trunk being open. This is clearly there if the key cylinder gets popped out of the trunk during a burglary. If this plug is Unplugged, it acts like its not there and will NOT allow the secuirty system to arm, unlike previously stated in other posts. With this unplugged, missing or faulty, your parasitic drain will be about 100 milliamps.
-matt
Old Sep 22, 2008 | 06:37 PM
  #91
JY05's Avatar
probably the alternator.. had that problem with my maxima
Old Sep 22, 2008 | 06:44 PM
  #92
Nice one n00b. The problem has already been solved.
Old Sep 22, 2008 | 08:51 PM
  #93
matty's Avatar
Read the thread dude
Old Sep 23, 2008 | 08:19 AM
  #94
choray911's Avatar
Bless his heart, he just wants to fit in.
Turd Nugget.
Old Oct 4, 2008 | 06:07 PM
  #95
matty's Avatar
UPDATE:
Its been two weeks and I use my car about every other day, sometimes it sits for two days, and starts up right away, same strong start, every single time I turn the key. Still drawing 10 milliamps after going into sleep mode and the security system arms correctly every time.
Thanks for all your help guys. The cars a differnet car now, now that I count on it starting.
-matt
Old Oct 10, 2008 | 06:22 PM
  #96
SpeedCrazie's Avatar
Any chance for a write up or is this a pretty simple swap? Also do you have a part number or name for the piece you replaced?
Thanks.
Old Oct 11, 2008 | 02:44 AM
  #97
matty's Avatar
Thanks.
It pretty much a simple swap. With it already in there, just take it off and replace if you test it and its bad(security system not arming). This is not a part you can jusy unplug and your car will think its there. WRONG !!
The Part number is:
84665-40U00 SWITCH ASSY-TRUNK $63.38 list....paid $47.87
Alot of body shops overlook this part and wont replace it if it gets banged up.
-matt
Old Oct 11, 2008 | 06:05 AM
  #98
Nopike's Avatar
-matt
Originally Posted by Nopike
Even with the wiring for the trunk lock cylinder switch disconnected my Maxima went into sleep mode (to approx 12 ma) after 30 seconds. This is as I expected. It does not hurt to install the switches. The whole problem is kind of wierd. Maybe the poster who said 100ma should be acceptable is right. It just seems like a bad design that a security switch malfunctioning would drain the battery. I guess you should still pursue trying to get the Maxima into sleep mode. I am learning a litte about the system from the FSM but it takes time. I also now have a flashing airbag light to deal with.
Glad your car is still working.
Old Oct 20, 2008 | 07:04 AM
  #99
max80228's Avatar
HI I was looking at this truck sensor for the lock on my car. As I too have a 100ma draw. How would I tell if mine was bad? Can I test the resisance? If so which wires and what should it read? I really need to find what my draw is.... As I have spent countless hours searching. Thanks
Old Oct 20, 2008 | 04:14 PM
  #100
matty's Avatar
Try arming your stock security system and see what the light on the dash does ? If you arm the system and the red light stays solid then in about a min it blinkes about 3 seconds between each blink, then its armed. If its CONSTANTLY blinking every second, even after the car is locked, then theres a fault in the system.
Old Nov 19, 2008 | 09:29 AM
  #101
max80228's Avatar
OK I finally was able to take my car back to Nissan. I have the same issue with the battery being completely drained after 24 hours of the car being started. I have traced, and traced with no avail. I was told last May that it was my alternator so Tynans Nissan in Aurora replaced it for $700- So i took it back for them to look at the problem and was told that I needed to start by replacing the cables from the battery cost of $450, they suggested replacing the starter because thry dont think its a Nissan starter another $500. I have owned the car since 2001 when it had 55,000 miles so I bet its still the original starter. Anyways I need to know if I should try to find some cables in a junk yard? Or start looking somewhere else? If so where? I have had the multimeter on and it draws 100ma all the time. Pulled fuses, relays, have been through about 7 batteries in the past 2+ years since this has been an issue. Thanks in advance for everyones help I appreciate the dedication to this site and helping fellow maxima owners.
Old Nov 19, 2008 | 02:06 PM
  #102
Nopike's Avatar
Thay all sounds like BS, looks like you have the 100ma draw just like Matty, this is probably because your allarm sysetm is not being armed. Faulty trunk, hood or door switch would do that. Busy now will try to help later.
Old Nov 19, 2008 | 02:15 PM
  #103
Nopike's Avatar
That all sounds like BS, looks like you have the 100ma draw just like Matty, this is probably because your alarm system is not being armed. Faulty trunk, hood or door switch would do that. Busy now will try to help later. Sometimes the dealers mechanics don't know s***.
Old Nov 19, 2008 | 02:26 PM
  #104
max80228's Avatar
Is there a way to test the resistence of the switches? What should they read? I am also tending to believe that it has something to do with the alarm system. It is the stock alarm, nothing else in the car is aftermarket..ie radio, ect.
Old Nov 19, 2008 | 07:29 PM
  #105
Nopike's Avatar
First you need to check if your alarm is arming itself and working. If not than that's almost certainly causing your problem. That information is contained within these posts. All the things that have to occur for the alarm to arm itself are also listed in one of the posts. A switch is either closed (zero resistance) or open (infinite)resistance. You can google that basic information to learn to operate a meter. Most of the information you need to resolve your problem is contained in these threads. I will try and help but I can't start teaching basic electronics.
Old Nov 20, 2008 | 06:54 AM
  #106
max80228's Avatar
Perfect thanks I will report back when I have time to troubleshoot probably this weekend.
Old Nov 23, 2008 | 08:17 PM
  #107
matty's Avatar
Lock your doors and tell us what that red light on your dash does..
matt
Old Dec 1, 2008 | 11:06 AM
  #108
max80228's Avatar
HI when i lock the doors the light stays lit for 30 sec, then blinks every 3 sec.. Is that normal?
Old Dec 1, 2008 | 11:23 AM
  #109
IIRC, yes.
Old Dec 1, 2008 | 02:21 PM
  #110
Nopike's Avatar
Looks like you alarm is arming and the car is probably going into the sleep mode. So all your alarm related switches are probably OK.
Maybe you have a different issue. You would need to check your current draw the way Matty did to see if you actually have a parasitic drain.
Old Dec 2, 2008 | 07:24 AM
  #111
max80228's Avatar
I have had the multi meter on the battery and the draw is 100ma, it never drops down. In turn the battery is dead in 24 hours.
Old Dec 2, 2008 | 09:33 AM
  #112
Nopike's Avatar
When you are doing this test have you depressed the hood latch switch with your finger? You need to do that to get in sleep mode (10ma). The alarm won't arm with the hood open so you have to depress the switch. should go into armed/sleep mode about 30 sec after you depress the switch. See below:
I checked my 98 SE which works normally and does not have this problem. I opened my hood and checked current with everything else off and closed. The draw was approximately 0.1 Amps = to 100 milliamps. This is the same as Matt's result. If I depress the switch that senses if the hood is closed after about 30-60 seconds the current draw goes down to about 0.01 Amps or 10 milliamps. This must be the sleep mode kicking in. That is quite a a difference. I can understand if another switch from the alarm system is malfunctioning, of missing, the car would never go into sleep mode.
Old Dec 2, 2008 | 11:02 AM
  #113
max80228's Avatar
Yes i held the switch down with my hand when I tested for the sleep mode working. I need to exchange my battery again as it has been through the ringer draining so often and I will verify with a brand new battery that the sleep mode does not happen. thanks
Old Dec 2, 2008 | 02:48 PM
  #114
Nopike's Avatar
This is from the FSM faults in any of the following would probably prevent sleep mode operation.
When any one of the following switches are turned ON, the “sleep” mode is canceled:
I Ignition key switch (Insert)*
I Ignition switch “ACC” or “ON”
I Lighting switch (1st)
I Door switches (all doors)
I Trunk room lamp switch
I Hood switch
I Trunk lid key cylinder switch (Unlock/Tamper)
I Multi-remote controller
I All switches combined or connected with door LCU
* Also, when key is pulled out of ignition (ignition key switch is turned from ON to OFF), the “sleep” mode is canceled.
Old Dec 2, 2008 | 02:50 PM
  #115
Nopike's Avatar
Get a copy of the FSM it's all over the org page EL-175 has an on board diagnostic test you can use to check your system out.
Old Dec 3, 2008 | 07:37 AM
  #116
max80228's Avatar
OK I will find it and move on to the next step.
Just FYI brand new battery put in yesterday, exchanged- and I left the multimeter on for 20 mins still was at 100ma....
Old Dec 3, 2008 | 09:27 AM
  #117
Nopike's Avatar
There is a section in the FSM that tells you about sleep mode , just go to the electrical section and search "sleep".
Old Dec 4, 2008 | 07:44 AM
  #118
matty's Avatar
Yea I had the exact same problem...you need to troubleshoot and find the missing link
-matt
Old Dec 29, 2008 | 08:11 AM
  #119
max80228's Avatar
Hi I was able to use the EL book I downloaded to troubleshoot the electrical system. I found that the anti-theft system is good. But i was able to verify that the charge indicator on the dash does not turn on whent he car is in the "on" position. I was able to visit the closest Nissan dealership to speak with a tech. The tech showed me how to test if the light works by grounding a wire to the body. I disconnected the connectot that has three wires then goes to two wires into the alternator. Then on the red/white lead touched a wire and grounded- had the ingition on run and the light turns on. So is the problem internal on the alternator? I was told that I could bring the car to this dealership as my reciept was from another Nissan dealership and the warranty work can be done anywhere. Is this light not functioning properly causing the parasitic drain?
Thanks for reading...
Old Dec 29, 2008 | 08:22 AM
  #120
Nopike's Avatar
Charge light not coming on is probably not related to the parasitic drain (10ma is normal when car goes into sleep mode) but considering your problem with the battery getting drained It would be wise to fix it.
