Brake light won't turn off
Old Sep 4, 2008 | 07:10 AM
Dexter's Avatar
Hi guys, I have a little problem with the Brake Light, it won't turn off. I checked the E-brake and the cable hasn't snapped (which was my first thought). And I make sure it's completely disengaged everytime I drive. Im gonna try to tighten it up to see if that helps it disengage better, beyond that any ideas?
Old Sep 4, 2008 | 07:19 AM
kdarcangelis870's Avatar
Could possibly be low fluid level in the brake fluid reservoir.
Old Sep 4, 2008 | 07:35 AM
internetautomar's Avatar
mod or sell?
Old Sep 4, 2008 | 10:16 AM
Dexter's Avatar
I didn't think of that. Might be the problem, i'll look into it. Thanks.
Old Sep 4, 2008 | 01:57 PM
DBear's Avatar
If the level is low and you don't have a fluid leak, it probably means your pads are worn and need to be replaced.
Old Sep 5, 2008 | 12:41 AM
Rob20's Avatar
i think hes on the right track, my max did the same thing and it was the brake fluid it was leaking a little bit and then it went to alot some guys at leschwab-not sure if i spelled it right.. must have hooked up or messed something up during brake flush but anyways they fixed it for me for free since it was under warranty.
Old Sep 5, 2008 | 07:14 AM
maxima92se's Avatar
+1 on the low fluid. Indication of worn pads.. or leak.
Old Sep 5, 2008 | 11:03 AM
vilmaxima's Avatar
could also be the connector on the e-brake(for the e-brake light), might wanna check that too.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
