for those with under neon kits?
can anyone post some pics on where to mount the tubes under the car so the tubes will not show at the bottom from a far distance. A few car in my town you can see the tube as they drive by.
thanks Brandon
thanks Brandon
Re: for those with under neon kits?
well i mounted them under my car but i did not use the black brackets that they sent me i used flexible metal do i could place the neon tube all the wat to the car as possible......the onyl way to do it so u dont see the tube is move the neon light closer to the middle of the car and then u wont se ethe glow as good.......i have mine mounted right under the car where the lil lip is where u put the factory jack to lift up the car....u can se every little of the tube whenu are far away..........the hardest tube to mount is the front tube.......the only way to hide the front tube is to cut some of the plastic under ur car........u will see what im tlkaing about when u go to install ur underbody glow kit....any other questions just assk.....
thanks Brandon
thanks Brandon
Originally posted by Llfe
or else get a body kit and the lights won't show...i mounted the front like right under the plastic...shows all the time but oh well...it's freakin bright at night
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
