1995 Maxima blown head gasket. . .1000 bucks. .. what should i look for
Old Sep 16, 2008 | 12:08 PM
josh662234's Avatar
I found a 95 maxima with 180K on it for 1000 or B/O. "Seller is MOTIVATED" She claims it has a blown head gasket. Thats what her mechanic said. I know blown head gaskets are really uncommon in our cars. The story is that she drove from San Jose to San Fran (50 miles) and just kept pulling over and adding water. It was also 100+ degrees out.
I'm thinking it may just be the thermostat or the water pump. What are some things i should keep a sharp eye out for?
Thanks in advance
Old Sep 16, 2008 | 12:46 PM
Feldman's Avatar
coolant in the oil or oil in the coolant. white or blue exhaust smoke. If is coolant as she claims it would be white. Get it warm and then push it to redline and you should see some white smoke if there is coolant being consumed.
Coolant is leaking somewhere if she was adding water every 50 miles.
Old Sep 16, 2008 | 03:31 PM
josh662234's Avatar
Thanks Feldman. . . the total trip was 50 miles, i guess she had to stop a couple different times to add water.
Old Sep 16, 2008 | 04:39 PM
Feldman's Avatar
sounds like a pretty substantial leak, you will know if it is going out the exhaust (head gasket leak) or coming out of a fitting pretty quickly i would suspect
If it is a head gasket and is losing that much fluid it probably wont run too well either
Old Sep 16, 2008 | 06:06 PM
internetautomar's Avatar
mod or sell?
you should look for a better deal.
I paid $700 for one that might have had a bad head gasket, but turned out to have no problem other than that all the coolant had disappeared from the system I filled it when I bought it, and it ran fine until the CEL came on for KS and o2. Sold it after that.
Old Sep 16, 2008 | 09:46 PM
ajcool2's Avatar
I just bought a 97 with a blown head gasket for my girl and we started it up once yesterday and the oil looked like mud and was spewing out of where dip stick is. We are swapping the motor friday.
Old Sep 16, 2008 | 10:23 PM
Feldman's Avatar
i would wait for a better deal unless you find out the leak is somewhere other than the head gasket
Old Sep 16, 2008 | 10:35 PM
maximase86's Avatar
I love lamp.
One of the local guys here picked up a 97 with a blown head gasket. It's pretty bad, chocolate milkshake for oil, runs with a horrible miss. Luckily he has a spare motor to put in.
Old Sep 17, 2008 | 06:11 AM
93altima's Avatar
Turbo 4th Gen
i would recommend buying it and 3.5 that *****
halfpol
Oct 17, 2022 12:16 PM
acw
Aug 13, 2015 12:50 AM
jholley
Aug 11, 2015 09:38 AM
acw
Aug 7, 2015 04:20 PM
halfpol
Aug 5, 2015 08:24 PM
