Wierd problems
Old Sep 16, 2008 | 01:49 PM
'96 B-rad's Avatar
Wierd problems
Hey, so the first problem isn't to wierd but the second one is. First one is that sometimes the a/c doesnt blow out air until I hit underneath the glove compartment. The lights fill up for full power on but no air comes out, so is that the fan/motor going bad??
The second one is that the other night when I started my car it started a little funny, I put it in reverse and the idle dropped to 300 and was bouncing up from 300-500 back and forth. I put it back in park and it went up to around 1200, so I reversed and it didn't do it so I back out of the spot and as I was driving the car didn't seem to have much power and when I turned to exit the rpms dropped to zero and the car just shut off. I started it back up and it was still driving sluggish so I just floored it and then it was driving perfectly normal. The next day it was driving sluggish so I floored it again and then it has been driving perfectly normal ever since then. The cel isn't on either by the way. Any ideas?? Thanks
I just had my mechanic put on front brakes and this all started right after that if the two could be related in some way.
Old Sep 16, 2008 | 02:13 PM
Feldman's Avatar
first problem is most likely the fan going bad, i had an accord where i lost one of the fan contacts and whenever it would stop where the contact was missing it wouldn't start up unless i hit it or hit a bump.
second problem sounds like it might MAF related any codes show up? you might want to get your codes pulled from an auto parts store. your cel wont light up until the code shows itself a few times but it will be stored on there until an obdII scanner clears it.
Old Sep 16, 2008 | 02:17 PM
QNO_A32's Avatar
well, its not that weird, being that idle is directly related to front brakes.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
