EVAP Codes > Me. Yes another CEL thread.
Old Oct 5, 2008 | 06:22 PM
slow97maxima's Avatar
member
So i have been trying to get rid of my CEL for a few months now, the car is a 97. Codes are:
0807 (P0443) - EVAP Canister Purge Control Valve/Solenoid Valve
and
0705 (P0440) - EVAP (Small Leak)
I tested the valve and it works fine, and as for 0705 there are about 700 possible causes for that code.
I don't know if its related but my MPG sucks, about 300 miles from full tank till the empty light comes on. driving style is extremely conservative, its my wife's car and she drives like my grandma.
So i know many have had evap codes/problems, and i hope someone can show me the light.
Old Oct 6, 2008 | 07:11 PM
l3ftonm3's Avatar
and
You tested the white plastic piece correct? Or did you just test the vacuum cut valve, the piece that has the wires running to it.
Old Oct 7, 2008 | 06:50 AM
member
I tested the mushroom shaped valve with 3 hoses attached to it, it tested out ok
Old Oct 7, 2008 | 06:57 AM
njmaxseltd's Avatar
Did you test it both for electrical operation and vacuum?
Check your gas cap.
Old Oct 7, 2008 | 09:31 AM
member
The one I tested for didn't have electrical components, it was simply a valve that had 2 large vacuum hoses and one small one, the one with the electrical connector is close to it, it has a 6 wire plug. I only took it apart to check for charcoal buildup but found none, I haven't tested it does anyone know the procedure? As for the gas cap how do I know if its doing its job correctly?
Old Oct 7, 2008 | 03:31 PM
devilz05's Avatar
Shift_3.0
I have the same codes as you. I'm not going to bother fixing it but my mechanic says a 0440 codes usually means the Catalytic converter is going.
2 cents
Old Oct 7, 2008 | 05:40 PM
member
my cat converter is about 5 months old....so i sure hope not.
Old Oct 7, 2008 | 07:37 PM
Problemchild1one's Avatar
i got the same code P0705 says Trans range sensor
Old Oct 7, 2008 | 07:38 PM
^^wthell can i do to fix it
Old Oct 7, 2008 | 07:55 PM
member
I do not have code P0705, with the self diagnostic test i have code 0705 (code P0440). Anyone else have any experience with my evap codes?
Old Oct 7, 2008 | 10:00 PM
whitegold's Avatar
300 miles before the light turns on? im lucky if i get 200 on a full tank
Old Oct 12, 2008 | 01:27 PM
member
Any other suggestions? What should i start replacing first? How can i tell if the gas cap is bad, i know it seals well as i hear pressure release when i unscrew it. Any way to test the canister purge control valve?
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
tseng1023
Oct 15, 2015 08:30 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
