ABOUT: HID kits in 4th Generation Maxima housings
visit these sites to see the disastrous effects of HID kits(nasty beam pattern, Glare, just plain nasty). I know you die hard HID KIT fans are going to argue that I am wrong, but pictures, and videos speak louder than words.
http://www.hidplanet.com/forums/viewtopic.php?t=21129
if you can't see the thread (not signed up, etc. I put up some video and pictures in my last post
and this on the general lack of quality control and standards on the part of the HID KIT community, although there may be few exceptions (look at bottom posts for this info, since you have to sign up to see it in the link)
and no matter what any seller says, Philips no longer makes HID kits. They tried for a while in europe but it became too legally problematic so they discontinued all HID kit lines. HID kits are rebased bulbs.
Edit: To clear things up, I am trying to say that HID bulbs placed into halogen reflectors are very dangerous and produce much less usable light on the ground, and a lot of glare to other drivers. HID kits are where most start their HID endeavor, but I feel it should only be a temporary patch until the money for a retrofit comes along.
for those who cannot see the second link, a bit of light reading (part 1 of 3): Author is a bit less critical then I about the subject
continued in next post
The 5.5 gen HID housings were engineered as D2R housings, which means that the reflector used minimizes glare while trying to utilize as much of the light as is possible with reflectors.
The Department of Transportation in the U.S and most states vehicle codes say it is illegal to put HID bulbs in a housing that was not made for it. Look it up
part 2 of 3
due to 5 picture limit, next post has part 3
and part 3....
a picture from same thread
here is a youtube video of HID KIT in the daytime, all other videos from same thread in HIDPLANET
http://www.youtube.com/watch?v=fd-b4...search=Hidding
yet more glare
http://www.youtube.com/watch?v=jdG9v3VcWEE&NR=1
http://www.youtube.com/watch?v=hwXfEGaoWmg
http://www.youtube.com/watch?v=5KtOk...eature=related
http://www.youtube.com/watch?v=QzZZq...eature=related
http://www.youtube.com/watch?v=uUBbF...eature=related
anyone need anymore proof of glare?
and a quote that has some relevance
Posted originally by Ocelaris on HIDPlanet forums:
This post is to hopefully give a brief explanation of the background of HID kits, and help new users understand the common opinions of members here. It is NOT a bash on HID Plug and Play kits, merely a basis for understanding.
We hope this furthers your interest in HID lighting for your vehicle, and clears up a perceived attitude around here. There is no right or wrong, good or bad. We all started with HID kits and some have made investments of time and energy to move forward.
We hope that you feel the same.
-HIDPlanet Moderators
We have indeed, bottled fire
HID kits are illegal in the USA because of DOT says so. Period.
Good or bad, we start from there.
Standard 108 says that you can not put a HID bulb in an headlight which was meant for a halogen housing. One reflector is made for a thin strip of tungsten, and the other an arc tube which is round. The modern free form reflector/projector is designed to a tight enough standard that even if the arc tube is in the exact same spot as filament bulb, there will be stray light, hot spots etc... That is their reasoning, and we do not debate that because they make the laws.
What this means for you is that HID Kits are a black market. DOT will shut down any US importer of HID kits large enough to be worth the effort. They have ruled repeatedly that "off road" or "show only" kits are still illegal, you MUST have a valid "on road" use in order to legally import a product for US vehicles.
What ends up happening is you have literally thousands of different manufacturers producing kits for a limited time, changing names, brands products etc... may be the same company, may not be, but that limits your recourse if the kit goes bad etc... typically 6 months is the limit you will see a new brand on the market.
The challenge that these small manufacturers have are 2 fold, and will explain why a lot of people do not reccomend them.
1) Electrical ballast
2) HID bulb
1) Electrical
The HID ballast is a counterpart to the bulb, and must match it's electrical requirements exactly to the mixture of gas/salt in the bulb. The requirement is to turn 12volts DC into both an explosive charge at 24,000 volts momentarily, and then match the steady state 85 volts AC that the 35 watt capsules require to stay lit. This requires high frequency switching transistors, and makes a lot of heat and is very taxing. Smaller manufacturers may skimp on components inside the ballast, may not have water proof enclosures, or simply have a bad design which doesn't last.
Here is what a ballast must do electrically to match an HID bulb:
HID kits range in quality from OEM standards (good), to not even working properly out of the box (bad). The most common problems seen are flickering, high pitched whine, or overheat and cutting off.
2) Bulb
HID bulbs are a variation on metal halide bulbs which are commonly used in warehouses etc... They have a mixture of xenon, mercury, and other "metal halide" elements. The manufacturers must make a cocktail of salts/gases which will last a long time, produce a uniform color over their life spam (called color shift), and ideally produce a good color spectrum.
All HID bulbs shift to blue, and become dimmer as they age, this becomes exacerbated by smaller companies with no one to monitor their quality. You the consumer 1 year down the road have 0 recourse with them. Where as OEM consumers like car manufacturers can sue and/or not do business with them if they are having a lot of problems over the life of the bulbs which they have a warranty to keep.
Typical problems with after market HID kit bulbs include uneven brightness and color shifting of bulbs resulting in mismatched headlights. Not to mention bulbs failing at different times.
Here is a picture of a 5000k 400w HID bulb where you can clearly see the salt mixture.
The point of this discussion above is to show that smaller manufacturers have lower standards because it is a black market, and OEM manufacturers have higher standards. It's an economic situation which should explain people's preference for OEM equipment.
Besides quality standards, OEM components adhere to regulations on color temperature and spectrum. The only color which is legal is a nominal 4000k sometimes called 4300k or 4100k. As HID bulbs age, there is a 5000k bulb sold which is called "color match". OEM branded 6000k bulbs may be purchased, but never come on a new vehicle.
Color Temperature, Color Rendering, and the Blue Effect
HID kits are affected by their perceived color, their quality of light, and obviously the bluer the bulb is. OEM stay to one standard, and Aftermarket can do whatever they want. These are usually not discussed, and there are direct trade offs. The bluer the bulb, the less light you get because the salts which are more efficient are in the red/yellow spectrum. Mercury which is the blue part of HID bulbs is very inefficient. Sodium which burns red on the other hand is very efficient. The Scandium/Sodium (na/sc) is the red part in the picture above. Below you see how each salt has an effect on the ignition of the bulb (blue spark at start is mercury) and once it heats up to a certain temp other salts can ignite as well.
Aftermarket manufacturers make tradeoffs to give you the consumer a purple bulb, but which has less light, and poor color. OEMs must stick with one standard.
Probably the most commonly misunderstood concept in lighting, Color Temperature is a relative scale of appearance of color. The problem is that color temperature is designed for astronomy, measuring of a sun which has an equal distribution of color in it's range from UV 400nm to 800nm Infrared. Example here:
2) HID bulb
1) Electrical
2) Bulb
part 2 of 3
originally posted by Ocelaris on HIDPlanet.com
As you go higher in color temperature you shift to more blue, and less red basically, hence people associate a blue color with higher and red with lower. Generally correct, here are some more graphics for explanation:
Do not take these as representative of REAL... because the trick with all HID lighting is that they are not a smooth distribution of light. Each HID bulb has peaks, and because it is not smooth, you could end up having an 8000k bulb which is normally understood to be blue, be red. Color temperature is only an approximation, so pretty much anything goes, and there are no real good ways to tell precisely what it will look like.
So because there are spikes, some colors do not display correctly, this has a name, Color Rendering Index or CRI. On a scale of 0-100, 100 is a smooth equal distribution of color, and 0 is monochromatic like a colored LED. Typical Car HIDs are in the 65% range CRI. They do not make a higher color rendering bulb... yet.
and part 3....
Posted by Ocelaris
Here are two pics to illustrate Color Rendering Index which I feel may be the most important if not misunderstood part of lighting and HID kits.
This pertains to HID PNP kits because CRI and luminous efficiency are mutually exclusive. Meaning you can either have a high CRI or high luminous efficiency (output). You can not have both. A High CRI requires a complex mix of salts and is expensive, you can rest assured aftermarket PNP manufacturers do not use these. One way to compensate for this is to use a higher mix of mercury which will shift the color to the blue end which makes it appear brighter.
Everyone loves blue, it's nothing to be ashamed of, but in lighting you need to be aware of it's effects. The eye is nearly twice as sensitive to blue light as green or red, that means equal power blue and red makes it seem blue more powerful. This is terribly over simplifying it but it will suffice for our topic, the truth can be found here:
http://www.handprint.com/HP/WCL/color1.html
The problem with that is that the blue rods/cones are in the outside of the retina, not the center, so it makes it difficult to focus on. Try focusing on a pure blue light in a dark room, bob your head back and forth you will see what I mean, it takes time for the light to "settle".
So blue light is bad for lighting the roads because it makes it difficult to focus, this accounts for most people's bad impression of HID kits in the rain etc... where lower visibility is already an issue. But the blue spectrum also is less efficient inside the bulb, it makes less light than a bulb with say more red... as can be seen here, sodium is red, mercury is blue, and metal halide is somewhere in between.
In summary, you can see that HID kits are a very poorly regulated market which plays on the lack of knowledge that people have about lighting, and because of this, most people on these forums will recommend OEM components because of their repeatability and standards.
Posted by Haknslash
I was doing some searching and found some GREAT videos to show all those people who swear kits don't have glare or they are better than stock halogen. Here is the proof:
the first video is great because not only does he have one HID kit in one headlight and the other stock to show good differences but you can also tell just how much glare you get. Also notice that the halogen side is actually puting out more useable light on the GROUND, where it counts!
http://www.youtube.com/watch?v=AcX63...search=Hidding
Check out this HORRIBLE narrow beam pattern. Notice how blue and stupid everything looks. Smurf-style y0!
http://www.youtube.com/watch?v=W4Rdi...search=Hidding
Mmmm glare
http://www.youtube.com/watch?v=bcnfA...search=Hidding
Mmmm glare
yet more glare
Posted by need4speed on HIDPLANET:
lol! hak... but you know no matter what we show them.... kits will always be the shizzle! no matter how many pix, videos, technical explanation, etc... we can explain till the cows come home... there will still be ppl thinking their kits are the shizzle.
IMO ... if you want to do High Intensity Discharge lights ... it should be done right. The only right way to use HIDs on our cars is to retro in a set of projectors. The glare might not be that bad for you while you are driving, but it blinds oncoming trafic. That being so ... I wouldn't take a chance of blinding a car that could cross into my lane and kill me. Save your money, do it the right way (retro fit FTW!) and be done with it.
To those with HID kits and no retro ... why not post some videos / clips so we can see, without having to sign up on yet another forum. Be sure to get clips of the car coming at you
lol I understand, it's the 'cheap' way to go, but at the same time ... it doesn't cost that much really. I did my own retro for ~260 or so, maybe 280 can't recall.
As most of us know ... ebay = you get what you pay for. The quality is not that good for most products, but that's not true of all of them. Allen ... what is this 'moving bulb' you have .... where did you get it, and how much was it?
OEM HID setups use projectors, where do you think we all get them? lol They are set up from the factory and don't even come close to glaring like an HID set up w/o projectors. Have you had your car come at you, with the lights on ??? Try it sometime, you'd be amazed at how hard it gets to see. I'm talking about a real driving experience, not just standing on the side of the road and looking back. You are only using 1/2 the output by not having projectors. Even if they are aimed low, it's the intense glare that radiates .... and because they are not in a set of projectors, that light just spills out all over, it's not directed really.
lol I understand, it's the 'cheap' way to go, but at the same time ... it doesn't cost that much really. I did my own retro for ~260 or so, maybe 280 can't recall. As most of us know ... ebay = you get what you pay for. The quality is not that good for most products, but that's not true of all of them. Allen ... what is this 'moving bulb' you have .... where did you get it, and how much was it?
Thread has been cleaned up to show relevant information.
There are a lot of ASSumtions going on in this thread.
First off, where did the OP offer to do retrofits for anyone?
This thread does not suck. At least 3 times a week, someone post up asking about adding HID's to there stock housings. We then have lengthy replies stating all the OBVIOUS reasons why it shouldn't be done, glare, crappy output, etc, etc. Then, the poster manages to convince themselves, that 'it won't be that bad', and they are going to do it until they can afford to do a retrofit (read- Never). Search, it happends again and again.
This plays out week after week on here.
This thread is getting stickied. Finally someone has laid out all the reasons it shouldn't be done, even if they did just copy it, at least it is posted.
From now on, any new HID discussion NOT involving doing a retrofit is getting locked, with a link to this thread.
I really don't care about the aftermarket HID talk, really, you get what you pay for. But HID's should not be used in standard halogen housings EVER, and that is the point that needs to be made.
http://www.youtube.com/watch?v=yVuSSdZNsZw&NR=1
Consolidation (by phenryiv1) of some points made in this thread:
Most HID fans will tell you for correct pattern you need a retrofit. I know what your saying but you might confuse some. A good retrofit is always preferred to any drop-in HID kit in a reflector housing.
Retrofit is the only way to go if you want HIDs in OEM reflector headlights. If you want to learn about retrofitting search but the BEST info is on HIDplanet
4th gen housings absolutely suck and need to be retrofitted with projectors- but what about 5th gens? The 5.5 has hids from the factory without projectors. These are HID reflector housing that are made for HID reflector bulbs. those are designed for that kind of lighting, but the cutoff is not as good as a projectors. iirc 5.5 had projectors in them as well
This information is necessary to keep young stupid drivers to drive safe and keep unnecessary stuff off of their car. Or in this case, keep HIDs off of cars that glare on coming cars and drivers. These glare effect other drivers and make the roads unsafe for other drivers. Think of others and how it will effect them, when you do modification to your car.
Finkle
Sep 27, 2015 09:53 PM
Greenmaxspeed
Aug 31, 2015 09:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
MikesChevelle
Aug 6, 2015 11:36 AM
