clutch not engaging after trans rebuild
Old Oct 8, 2008 | 06:15 PM
rockfordmaxII's Avatar
i just finished installing my rebuilt 5 speed and i am having some problems. it seems that i can put it in every gear but when i let the clutch out its like its not actually in gear. almost as if the clutch is not engaging at all. i can put it in gear and it will roll as if it is in neutral. and i did bleed the system. anyone?
Old Oct 8, 2008 | 06:23 PM
JtzMax's Avatar
Whatchyou say?
PMd you ...
You just answered some of my questions in my PM to you already. So, it goes into gear ok, but doesn't move. I'd say clutch for sure. Did you do the clutch (stage 3) at the same time? Only thing that comes to mind is grease on the friction disk, or you left out the IPS or the diff. I am sure you didn't do either of those so I'm not sure what to say here. Sorry ...
Old Oct 8, 2008 | 07:33 PM
pmohr's Avatar
No more Maximas...
Okay, here's a scenario. In gear, clutch engaged, engine running...what happens when you rev it up? Does just the tach rise, or the speedo as well?
Old Oct 8, 2008 | 07:34 PM
ok, figured it out, i was reallllly flippin scared that something was messed up in the trans itself, but it turns out that i have actually had this problem before haha. It has been a problem before, and bascially when installing my axle, the cv joint likes to slip out. therefore the axles would freely rotate but not spin the wheels. ahhh finallllly. now i just have to get a new cv boot and put it all back together. yay
Old Oct 8, 2008 | 07:36 PM
pmohr's Avatar
No more Maximas...
And as a result you'd be seeing the speedo rise revving it in gear
Good you got it figured out, though.
Old Oct 9, 2008 | 09:36 AM
yep, im satisfied, thanks for the quick replies, and i would recommend to anyone that wants to get a rebuild kit that driveline.com has much better customer service then gt transmissions. i also have a bearing that i received with the gt kit that im going to send back because it is junk and is loud as hell, i ended up using an old bearing because it was still in good shape and even better than the new one.
Old Oct 9, 2008 | 12:39 PM
JtzMax's Avatar
Whatchyou say?
Glad you got it figured out ... just didn't make sense that it was a trans problem.
That is the first thing I have heard bad about George (GT Trans) ... but if I need any other kits, I'll check out Driveline and see what they might offer. Thanks for the tip!
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
ef9
Oct 4, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
