Disaster installing AGX shocks today!
Well I finall y got the right rear on today with out major problem, then moved to the left rear, and bam! After about an hour of trying, even with my impact wrench, I couldnt get the bottom bolt loose. ended up STRIPPING it!! Once it was toast, I couldnt even brake it loose with an air chisel. So tommorow, I get to take a torch to it and a saw. Lets hope I can find a replacement bolt!!!!
That sucks...
I hate it when stuff like that happens. I stripped a bolt when taking off a lug nut, and the when it wouldn't come off the tip it just broke off. I just guess it was over-tightened or not properly torqued. Had to pay $40 to replace it (labor run alot on these things), but atleast I could drive it to Firestone. You can't even do that, do I feel your pain!
-Cyrus
-Cyrus
Re: Disaster installing AGX shocks today!
Same thing happened to me too. I striped the bolt beyond recongnition. I know how to fix it though
. Torch the bolt and nut real good and then use a "pipe wrench" to brake it lose. My bolt came right off when I did this! To bad it took me a whole week to figure this out.
Thanks for everyones advice. I'm kinda hoping that NAPA will have a replacement bolt that will work, otherwise it will be another week before I can have the time to put the new shock on. I'm not worried about F'ing up the old Tokicos cause both of them were shot after only a year, and it's just too much hassle to send them in for a hpeful refund. I was really looking forward to riding on them tonight with my new RSB, and seeing just how much of a dif the KYBs are to the Toks, and what kind of difference the RSB really makes. May be tommorrow....
Originally posted by tifosiv122
Yeah, I wanted it like that...but with the window switch installed I will leave it on all the time.
Erik
Erik
I had this happen to me twice. I use a propane torch to heat the nut up and teh bolt came right out. After everythime i do a suspension switch ( i have gone through 3 set-ups so far
) i just replace teh lower stud & bolt. This will prevent furture problems. Soaking down the bolts a few days prior to swap always helps too.
maybe you guys get over excited and use too much force
. Don't you all put a little WD-40 or liquid nails on the bolts before taking them off? All the bolts on my car were a pain to get off; i let them soak in liquid nails for like 15 min. Be patient
lol
LISTEN UP EVERYONE REPLACING REAR SHOCKS OR SPRINGS
YOU MUST SPRAY WD-40!!!!!! ON THE THE BOTTOM NUT OF THE REAR SHOCKS. THEY ARE TORQUED ON THERE VERY TIGHT SINCE THEY HAVE NEVER BEEN REMOVED. I AM SORRY I SHOULD HAVE POSTED THIS SOONER SINCE I KNEW ABOUT IT. SO DO YOUR FRONT SHOCKS FIRST SO BY THE TIME YOU COME TO THE REAR THE WD-40 SHOULD HAVE LUBBED IT UP SOME. YOU CAN USE ANY OTHER LUBRICANT I JUST CANT REMEMBER THE NAME OF ANOTHER I JUST USE THAT. AND YOU CAN JUST GO TO THE NISSAN DEALER AND GET A REPLACEMENT IT SHOULDNT COST YOU NO MORE THAN $2.00 PLUS TAX.
[IMG]C:\My Documents\My Pictures\001.jpg[/IMG]
Originally posted by sx7r
i don't use maps.
i don't use maps.
Well.. i did...until i sold it.
WHy go to the junkyard for old bolts when you can spend less then $3 for new nut & bolt? I replaced mine everytime i swapped my suspension (3 times already). Why go cheap...
Sign me up! Can you tell me where to get them? Dealer? Also, is the rear nut/bolt the same as the front two?
Originally posted by Mishmosh
Synki,
Synki,
i don't use maps.
i don't use maps.
Erik
Nor do I. Navigation is going in for Christmas/Birthday (12/4). Its a pioneer in dash DVD Player/Navigation with in dash 7 inch screen. Both fit in the double din and the screen has removable face.
Erik
Erik
Maxima_Joe
Nov 25, 2015 08:19 AM
