Another Retro :D
Old Oct 14, 2008 | 07:21 AM
AndrewR2442's Avatar
Another Retro :D **(need opinion on fogs pg.2)**
98 nissan maxima
r34 ebay headlights retro'd FX35's w/e30's
FX35 shroud (dremeled down)
194 orange accent light (not completed)
********* apexcone 55 watt ballasts w/phillips 85122+ bulbs***********
Old Oct 14, 2008 | 07:22 AM
194 bulb retro'd into the top(not completed yet)
Old Oct 14, 2008 | 07:35 AM
Mr. Blue Sky's Avatar
nice job on the retro, gives a newer look to the car, and has excellent output(for the size). You cut off the front shield to get that color right? My FX's have been a pain, and riddled with issues, mainly involving that damned shield.
Old Oct 14, 2008 | 08:21 AM
mtrai760's Avatar
'Trynna' is not a word
Nice job. I'm loving my FX35 projectors. I got fed up trying to get my shrouds to fit, I'll work on those again next summer. Looks like you cut the projectors down the same place I did.
Old Oct 14, 2008 | 08:58 AM
j2b4osan's Avatar
that looks great Ive ben wanting to do somethin like that for a while. does anyone know if any bmw headlight internals(halo projector) would fit in the max housing??
Old Oct 14, 2008 | 10:01 AM
darklegend06's Avatar
very nicely done.
SO how long did it take you to finish that?
Old Oct 14, 2008 | 10:08 AM
how long?.... let's just say too long.
about a month on and off. It was a little hard to make everything fit.
Old Oct 14, 2008 | 10:36 AM
riceyasian86's Avatar
I just got around to getting my new headlights in for my s2000 and now have a pair of s2000 projectors from my old set so I'll finally be able to do this retro to my max
Your retro looks VERY nice btw. Those projectors are huge lol
Old Oct 14, 2008 | 10:43 AM
Tatanko's Avatar
Bacon Lover
Wow, those look great. I think you've convinced me to make my next set with some FX35's My E46's aren't so great anymore compared to this stuff.
Old Oct 14, 2008 | 10:53 AM
maximase86's Avatar
I love lamp.
Your retro looks awesome! Did you wire up the projector highs or are you doing like mtrai and using the low beam only? maxgtr2000 finished up my cefiro retro...to bad I don't have a car to put them on any more.
S
Old Oct 14, 2008 | 11:01 AM
fat_kid's Avatar
looks great!
Old Oct 14, 2008 | 12:57 PM
99BlackMaxMS's Avatar
Those look awesome...thats exactly what I want to do once my s/c build is complete
Old Oct 14, 2008 | 04:27 PM
Oh my. What beautiful retro's.
Old Oct 14, 2008 | 09:22 PM
I wired up the bixenon function to the high beam of the 9005 bulb. It's very bright. Let's put it this way. On those dark back roads in the country... i don't get scared going 60 anymore.
*************** the ballast are 55 watt apexcone's w/ 85122+ phillips bulbs (that's why the beam shots are so intense)********************
Old Oct 14, 2008 | 09:25 PM
MROTH's Avatar
beautiful work!
Old Oct 14, 2008 | 10:04 PM
give us some later updates on how the fx bowl fares with the added heat of the 55watt HID's as I am thinking of going that route later on with mine.
Old Oct 14, 2008 | 10:45 PM
oc_wicked's Avatar
man that looks nice props on that retro!!!!
Old Oct 15, 2008 | 12:03 AM
95 Maxnout's Avatar
Very nice work man...
Old Oct 15, 2008 | 07:46 AM
kzoosho's Avatar
Drew i didnt know you were going with the 50 watters. I still dont think i can step up to the 50 since the 35 does me well. But great work my friend. I should have my new retro posted soon.
Old Oct 15, 2008 | 08:23 AM
I can answer the bowl question since i've had the 55 watt apexcone ballasts for about 6 months now. I drive about 45 minutes at night 3-4 times a week. The bowls of the FX are still in good conditioin after being subjected to boosting the bulbs wattage to 55 watts. .... I don't say great b/c the bowl does have an ever so slight hint of dullness to it when i looked at it..... I was looking for damage though, and i didn't find anything that would harm any output though. I havne't noticed any decrease in performance either. The DL50's are supposed to be the only bulb that is ok to use. Now i know that for a fact. I just wanted to see it for myself. Now i will be using DL50's in anything above 50 watts forever more.
The FX bowls are not sealed against the body of the projector. They have many openings for heat to escape. This may be a reason that the bowls stood up to heat so long... My last retro for the past 6 months left the rear of the projector open and unsealed at all.
And... here's a comparison in an open air test in a house. The actual temperatures will rise much higher in a completely sealed headlight. http://www.hidplanet.com/forums/view...=dl50&start=50
Old Oct 15, 2008 | 08:36 AM
MOHFpro90's Avatar
By far that ranks in the top 5 of best looking retros on here. Very nice job man!
Old Oct 15, 2008 | 09:24 AM
ChubbieBoi's Avatar
wow. . great job man..
Old Nov 12, 2008 | 01:20 PM
kzoosho's Avatar
Im copying your setup drew. Hope you dont mind.
Old Nov 12, 2008 | 02:00 PM
Tatanko's Avatar
Bacon Lover
It's for me
Old Nov 12, 2008 | 02:29 PM
It's all good... let me know if you run into any problems...
Old Nov 12, 2008 | 02:32 PM
kzoosho's Avatar
I sure will. I see i am going to have to either cut the projector or the housing . So i know what one I am going to do. Did you cut the projector down at all?
Originally Posted by Tatanko
It's for me
SHHHHHHHHHHHHHHHHh dont tell.
Old Nov 12, 2008 | 02:59 PM
I Massacred my FX's... I trimmed all of the oem mounting arms and then trimmed the glare shield off of the top of the projector. I had to trim the left and right sides of the projector also. So you are basically trimming the entire projector if you plan to use FX's. It cleared pretty well after that.
I ran into some problems w/the brackets from JNC's mounting method. I had to trim the brackets down so that the projector would sit low enough in the r34 housings to get a good angle on the road. So keep that L bracket short and little.
I had to JB weld my fx shrouds to the FX lens retainer cover. I used the slow jb weld but they have a 4 minute jb weld out now. Hopefully the spec's are the same as the original stuff.
You'll have to trim the inside of the housing down flat. I made the mistake of trimming outside of the circle that retains the end cap. That circle is important for the strucural integrity of these housings, as well as neccessary to fasten the new pipe fitting to the housing.
That's about all of the headaches that i ran into.....
Old Nov 12, 2008 | 04:00 PM
QNO_A32's Avatar
Damn you have the hottest retro on here
Old Nov 12, 2008 | 04:03 PM
kzoosho's Avatar
wow you got rid of the glare shield too? Did you loose intensity?
Old Nov 12, 2008 | 04:19 PM
petro2342's Avatar
Sick!
Old Nov 13, 2008 | 09:52 AM
Torgus's Avatar
awesome good job!
Old Nov 13, 2008 | 11:14 AM
Flava_24/7's Avatar
Boosted Panda
I like the Wizards better...
Old Nov 13, 2008 | 11:44 AM
JSMax's Avatar
Sold
yes flava I like the wizards setup better. But that fx35 projector looks to be a little more cost effective.
Old Nov 13, 2008 | 02:05 PM
Flava_24/7's Avatar
Boosted Panda
Yeah the S2k's are $$$, but the FX35's are just so big. If it were being used in a single setup where it was the only light source and using its BiXenon capabilities to me it would just look better, but it in the R34's with the other headlight next to it just looks odd to me. It does have nice output though.
Im not trying to bash, I was mainly responding to QNO_A32's comment about the best looking retro.
Old Nov 13, 2008 | 06:42 PM
aznsap's Avatar
very najs! how much did this setup cost you?
Old Nov 13, 2008 | 07:26 PM
Coolsaber57's Avatar
Wait, what does the 194 bulb do?
Old Nov 14, 2008 | 07:14 AM
This is probably similar thing to the cefiro city light thing.
So instead of having the Projector/headlights on, the 194 bulbs lights up, and gives the head lamp a small accent.
But looking at the placement of where he drilled the hole for it, it looks like it's supposed to light up only the back ground of the projectors, from behind the bezel. So you'll only see light coming from around the bezel. Kind of similar to the looks of the BMW halo ring, but I don't know how this will look.
Old Nov 14, 2008 | 08:35 AM
gtr_rider's Avatar
192.168.1.1
not bad, not bad...
Old Nov 14, 2008 | 01:35 PM
BiZzL3's Avatar
looks good.. nice job.
Old Nov 16, 2008 | 12:13 AM
InitialD's Avatar
Nice job. Very clean.
