HELP ASAP
Old Oct 29, 2008 | 12:52 PM
nyc96max's Avatar
HELP ASAP
I just did my z32 BBK , everything went well until the end. We started bedding the brake and it still smoochy and soft. We bed it at least 3 times
When you constant pump it it will hold pressure but when you hold the brake it will sink all the way down . I need help asap , im at the shop and dude is clueless.
Old Oct 29, 2008 | 01:05 PM
AndrewR2442's Avatar
AFter i removed one caliper from the brake line, my brakes had no pressure whatsoever. That's b/c i didn't bleed the one line at all... I just said f*ck it and went to an auto store and bought a hand vacuum pump for bleeding the brakes. It worked flawlessly. I reccommend it, since bleeding w/a person seems to be the hardlest to do.
or
just buy some speed bleeders that have a check valve in them, then you won't have problems either.
Old Oct 29, 2008 | 01:08 PM
njmaxseltd's Avatar
You need to bleed a lot of fluid through the system after you change brake components, like a quart or two. Also make sure the master cylinder never runs dry. If so, you need to start all over again with lots of fluid.
Old Oct 29, 2008 | 01:13 PM
nismology's Avatar
Never go to that shop again. Seriously.
The correct order for bleeding is right rear, left front, left rear, right front.
Old Oct 29, 2008 | 05:38 PM
nyc96max's Avatar
UPDATE: Change the master cyclinder and bed again from brake line and cyclinder , still no pressure driving . When car is off there is pressure and also like i said before constant pumping the brake will brake but if i step down the brake once it will sink down. PLEASE HELP
Old Oct 29, 2008 | 05:42 PM
Tuna's Avatar
But did you BLEED the brake lines????
Old Oct 29, 2008 | 05:52 PM
nyc96max's Avatar
yes i did all lines and master cyclinder
Old Oct 29, 2008 | 06:02 PM
JonBlz's Avatar
a.k.a. STuNtMAN
check for lleaks and all i had the same problem just have to bleed it COMPLETELY
Old Oct 29, 2008 | 06:06 PM
Tuna's Avatar
Either the lines weren't properly bled or you've got a leak somewhere.
Old Oct 29, 2008 | 06:10 PM
nyc96max's Avatar
I check for leak and came out negative and i did bleed it completely , i used about 2 1/2 bottles or brake fluid
We bleed it ( pump brake a few times , hold brake pedal down and loosen the nut on the caliper.) No leaks what so ever
Old Oct 29, 2008 | 06:13 PM
mtnbikeair's Avatar
Wouldnt the order be right rear, left rear, right front, and then left front. I might be wrong but my understanding of bleeding brakes was you started farthest from the master cylinder and worked your way to the closest?
Old Oct 29, 2008 | 06:17 PM
nyc96max's Avatar
can some vouch for this?
Old Oct 29, 2008 | 06:28 PM
nafddur's Avatar
FSM clearly specifies: right rear - left front - left rear - right front
Old Oct 29, 2008 | 06:34 PM
mtnbikeair's Avatar
Well ya learn something new everyday. Every car I has done you started from the longest line and went to the shortest, but glad to know this info for maximas.
Old Oct 29, 2008 | 06:35 PM
nyc96max's Avatar
ill try that tommorrow.
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
