Maf sensor? replacement
Old Nov 3, 2008 | 12:23 AM
Rob20's Avatar
I think my maf sensor is malfunctioning. my car dies at low speeds and sometimes doesnt want to accelerate. i take off maf sensor hookup the 4 screws on it and pull the 3 wires back and it car runs and works just fine. for a month maybe and then problem comes back, i do the same to Maf and problem is fixed. should i replace it. and is only replacement a stock MAF or can i go with something else?
Old Nov 3, 2008 | 08:09 AM
djipka's Avatar
did you try cleaning it. CRC makes a MAF cleaning spray that I use often.
Old Nov 3, 2008 | 10:51 PM
Rob20's Avatar
what part should i clean the inside bulb looking wire?
Old Nov 3, 2008 | 10:59 PM
djipka's Avatar
yes. you just make sure you that from a distance because those wires are way thin and sensitive.
Old Nov 5, 2008 | 12:40 AM
Rob20's Avatar
bought maf cleaner and cleaned today. runs better. knock on wood. thanks for help
Old Nov 6, 2008 | 04:01 AM
nymax99se's Avatar
where exactly is the MAF sensor in the engine bay because im having problems big time with my maxima???? engine hesitates getting up to speed.
Old Nov 6, 2008 | 05:37 AM
Bassbreaker's Avatar
the Maf Sensor is the 3" x 3" x 1" thing thats between your air intake box and the throttle body. It sit's on top of the piping running into the motor
Old Nov 6, 2008 | 12:51 PM
nymax99se's Avatar
ic it now.................thanks buddy.
Old Nov 6, 2008 | 12:56 PM
Madmax66's Avatar
Ah! Great thread - thanks! Mine is hesitating a lil and I already did the FI cleaner. I'll def try this! Is CRC product cd MAF cleaner?
Old Nov 9, 2008 | 11:38 PM
Rob20's Avatar
well heres another problem the little black thing sticking out of the MAF on the side had some lose screws so i tightened them in but car still dies on me and i know that its all MAF because i get out of my car and push the connector (that hooks up to the side) Down and car starts running and wont turn off.. Im done with this maf getting another one, im looking at used ones. Is the OEM maf the only maf i can use or can i use a different one?
Old Nov 10, 2008 | 04:32 AM
Madmax66's Avatar
How did you re attach the 3 wires? I yanked them by accident and it runs like s**t! Dint think it was possible to re attach.
Old Nov 10, 2008 | 05:10 AM
gold96's Avatar
cleaning MAF maybe better than replacing
I had a MAF engine code. I bought a "better than OEM" replacement MAF off of ebay. I put in in, reset the codes, and the car ran worse. Stalled right away when I started it, hesitated when I hit the gas.
I cleaned the old one with carb cleaner and tickled the wire with a hobbyist paint brush, put it back in, and reset the engine codes once more. Now it runs perfect. Idles at 800 in park and 600 in drive when warm.
Old Nov 11, 2008 | 07:13 PM
Sfblues7's Avatar
Sometimes i will start the car and let it idle for about a min then it suddenly stalls and i go to try and turn it back on and it will just crank but not turn over to start. So i will wait for about a min and then try agian and it will start up and i can drive, BUT sometimes it will hesitate and the car will bog down so i put it in neutral and the rpms were fluccuating between 600-1000 rpms and if i wait for a moment i can drive it where i need to go with no problem. Im thinking its MAF sensor? I took it off and looked at it but it seems really clean but it could still be bad? Any ideas?
Old Nov 12, 2008 | 06:26 AM
internetautomar's Avatar
mod or sell?
in your case, I am thinking IAC needs cleaning.
Old Nov 12, 2008 | 09:34 AM
Sfblues7's Avatar
Maybe for my starting problem but what about when the car hesitates when i accerlerate. (btw I havnt had the problem yet today, it only happened yesterday twice).
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
vanebecker
Aug 19, 2015 09:45 AM
