please help!
Old Nov 7, 2008 | 11:37 AM
Madmax66's Avatar
please help!
I foolishly yanked the 3 prongs out of MAF after removin 4 screws.they looked to be soldered. I pulled and cleaned MAF and put back properly. Car started fine but got code 0304 for KS!? I just replaced. Drives like crap! At 2500 RPM it sputters like mad! WTF! Help!
Old Nov 7, 2008 | 12:54 PM
Snypa's Avatar
simply replace wahtever is broken bro.
Old Nov 7, 2008 | 12:58 PM
maf2003111's Avatar
dont worry, ur maf is bad and thats why its doing it. when you took off the connections(which i think should never need to) its not on just right and thats why its not going pass 2500rpm. go to junkyard and get a MAF and ull be ok. dont know if its fixable now that you open it up.
Old Nov 7, 2008 | 01:23 PM
Madmax66's Avatar
So just get a new 3x3x1 box?
Old Nov 7, 2008 | 01:24 PM
nitromax's Avatar
i have a used one you can get quick & inexpensive. maf sensor,
let me know if you want it.
Old Nov 7, 2008 | 02:20 PM
pmohr's Avatar
No more Maximas...
What?
If you ripped the leads out of the MAF and you can't repair it, you need a new MAF.
Why did you try to remove the connector?
Old Nov 8, 2008 | 11:57 AM
Madmax66's Avatar
I was an idiot. I read a post bout cleaning the MAF...4 screws....ASSumed I needed to pull it. Brilliant move! Another guy said he was havin idle issues...opened the plug and pulled all 3 prongs back and it ran fine!?!? I'm just confused why I'm getting the 0304 KS code if it's my MAF that I f'd. I hope that's all it is.
Is there anyway to repair this? Seems impossible to solder. Another guy has a used one. Prob just easier to replace entire MAF?
Old Nov 10, 2008 | 07:55 AM
maf2003111's Avatar
I would just replace it. i got one for $60 at a local import junkyard where i live, see if you can find a used one. nitromax said he had a used one he would sell u.
Old Nov 10, 2008 | 08:50 AM
hornepirate's Avatar
Most cars always have th KS code...its a ghost code and it will go away after you replace your MAF...i replaced mine a year or so ago and when i plug up my scanner it still says its there...so don't worry about that just fix your MAF and don't pull anything soldered out of that one
