VLSD vs. non-VLSD axle differences?
Old Nov 19, 2008 | 05:19 PM
NISSANMAXIMA91's Avatar
I just got through replacing my CV axles, and the car has developed some clunks while stopping hard. Before anyone asks, my method for replacement was by removing the caliper and the the knuckle from the strut. Also, everything was torqued down to proper spec: strut knuckles at 110ft-lbs and axle nuts at 200ft-lbs. Replaced calipers, tightened them down and had an alignment done on Monday.
My concern is that from purchasing from Raxels (GREAT service by the way) is that after the order was complete and I had the axles, the thought crossed my mind that Marty never asked if the car had VLSD or not. Mine does not. When I compared axles, they all looked the same and appeared the same length so I thought nothing of it. But now with the clunks under hard braking, I'm concerned. So, can someone tell me if there are any major noticeable differences between VLSD and non-VLSD axles??
Thanks, NM91
P.S.- This is on my 96 auto.
Old Nov 19, 2008 | 05:26 PM
MaXiM@KiD's Avatar
MaXXiN
On the driver side the axle is bigger (spline that goes into transmission) so it wouldn't fit into a open dif. The passenger side wouldn't matter as far as I know. I just purchased a vlsd transmission and ONLY had to change the driver side.
Old Nov 19, 2008 | 06:39 PM
internetautomar's Avatar
mod or sell?
VLSD axles have a second set of splines on the inner joint on one side.
Old Nov 20, 2008 | 08:01 AM
10psigti's Avatar
if they were the wrong axle they would not work at all as stated above the vlsd has extra splines on the inner shaft hence vlsd which uses the fluid in the diff to put pressure on the splines
Old Nov 20, 2008 | 03:05 PM
Ok. Thanks. Appreciate all the info everyone.
Old Nov 20, 2008 | 03:35 PM
TunerMaxima3000's Avatar
Do YOU even know what you're trying to suggest there?
Do some
Old Nov 20, 2008 | 11:36 PM
MaXiM@KiD's Avatar
MaXXiN
Point blank period...the passenger side doesn't matter...Like I said above...if the driver side were LSD it wouldn't fit as it's bigger than the open diff axle(splines that go into transmission). If you have any questions just PM me I've done my fair amount of research into this already
Old Nov 21, 2008 | 06:05 PM
Can you put a non LSD axel in a LSD?
Old Nov 21, 2008 | 09:09 PM
MaXiM@KiD's Avatar
MaXXiN
Not the driver side. The splines are bigger on the LSD axle. The passenger does not matter
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
