P0440 evap code?
Old Nov 21, 2008 | 08:08 AM
zx2max's Avatar
P0440 evap code?
I recently failed inspection because of CEL and when I pulled code it was p0440. I have searched the forum and it seems like that it a pretty generic code for evap leak. I don't have any other codes to narrow it down. I don't have the time or place (it's cold outside) to check each component of evap system. A little over a year ago I did replace the evap vent control valve so that's one thing that should be ok. I do think my catalytic converter is pretty old. Could that be a possible cause and if so what kind of cat would you recommend? Thanks.
Old Nov 21, 2008 | 11:06 AM
oldngivout's Avatar
Willing to learn
Your catalytic converter has absolutely nothing to do with the P0440 code, so you can rest easy there.
Old Nov 21, 2008 | 11:31 AM
njmaxseltd's Avatar
Check the canister, lines and valve behind the left rear wheel.
maxinout93
Oct 31, 2015 02:04 AM
tseng1023
Oct 15, 2015 08:30 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
