No heat, Help
Old Nov 13, 2001 | 07:55 AM
mipinc's Avatar
No heat, Help
I am not getting hot air in winter. The coolent level is fine, the gauge shows normal reading in summer and stay around 'C' in winter. If it is thermostat then how can I get to it? Is their air in the cooling system? Help!
Old Nov 13, 2001 | 07:59 AM
Sprint's Avatar
Re: No heat, Help
you may have a blow resistor.. this can cause your heating system to blow out.. i am not sure about all the info on it.. but i will search and i will let you know..
Old Nov 13, 2001 | 08:04 AM
RPalka
Please specify the year of your car and whether you have automatic or manual climate control.
Old Nov 13, 2001 | 08:05 AM
mipinc's Avatar
95 Max, manual control
Old Nov 13, 2001 | 08:12 AM
Sprint's Avatar
take some time to go through reading these threads.. and i assure you that you will find a solution to your problem..
probably be able to fix it..
http://forums.maxima.org/showthread....light=resistor
Old Nov 13, 2001 | 09:09 AM
Sprint's Avatar
wierd it doesn't have me as last person.. glitch? blah
Old Nov 13, 2001 | 10:24 AM
mipinc's Avatar
The problem is not this air speed but the heat in the air. All of my 4 fan speeds are working fine.
Old Nov 13, 2001 | 10:50 AM
Sprint's Avatar
sorry i misunder stood you man..
here you go.. hope this helps..
http://64.252.159.123/~doug/ha1-38b.pdf
if you need acrobat reader you can download it at www.adobe.com
Old Nov 13, 2001 | 12:52 PM
SuDZ's Avatar
Thats a great flowchart. Where did you get it? Are there others like it?
SuDZ
Old Nov 13, 2001 | 01:02 PM
Sprint's Avatar
that is a page from the Factory Service Manual..
SuDZ
Old Nov 14, 2001 | 06:48 PM
mipinc's Avatar
Do you have the procedure on how to bleed the air out of the cooling system. Also where is the thermostat located?
Old Nov 14, 2001 | 07:07 PM
Sprint's Avatar
http://64.252.159.123/~matt/4th_gen_esm/lc.pdf
Old Nov 14, 2001 | 08:37 PM
mipinc's Avatar
Thanks man!
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
