shudder on accel at low speeds
Old Nov 28, 2008 | 07:04 AM
rxm6's Avatar
just had axles replaced, never did this before axles.
doesn't shudder when not accelerating, just when accelerating between certain lower speeds. At high speeds i don't feel any shudder. Alignment needed? something else?
Old Nov 28, 2008 | 06:58 PM
Fasteddie01's Avatar
Not much to go on. Is the shudder seeming to be the engine misfiring, or just a vibration in the front end. ? Are you MT or Auto ? Could be motor mounts. Were the old axles noisy or just bad boots ? Really need more info to more than list guesses.
Old Nov 28, 2008 | 07:47 PM
maxboy325's Avatar
Probably motor mounts but yeah were gonna need more info
Old Nov 29, 2008 | 04:53 PM
tigersharkdude's Avatar
mine does the same thing after axle replacement. im auto. my axels popped around corners, and were tore other than that they were fine. its just a vibration. ive had 3 mechanics look at it and none of them knows what it is
Old Nov 29, 2008 | 04:56 PM
rxm6's Avatar
axles' boots were bad.
not engine either, this began to happen immediately after axles were replaced. by shudder, i mean, the steering wheel vibrates excessively between 10 and 35 mph on acceleration. there is no vibration while coasting either. If i'm coasting at 20mph and then i accelerate, the wheel will shudder. If i'm coasting at 45 and i accelerate, there will be no shudder. For reasons unknown to me, it only occurs at lower speeds. When i'm on the freeway, i have no vibrations which is why i was confused by it because if it was alignment i would think that i would feel it most at freeway speeds.
Old Nov 29, 2008 | 05:47 PM
the same hear, only from a stop up till about 20mph. mines not that bad, just annoying at first. now im used to it though. I know mines not an alignment issue because I have had 2 done since the axle swap.
Old Nov 30, 2008 | 02:53 PM
QNO_A32's Avatar
its the axles, your probably gonna have to replace them or maybe just one at a time you know
Old Nov 30, 2008 | 05:17 PM
I have had my axels replaced, twice!! well it started doing it after the first replacement, so I had them replaced again 2 days later and it still does it.
Old Nov 30, 2008 | 07:31 PM
EEMaxima's Avatar
My brother's Q45 did this at low speeds. It was the axles.
Old Nov 30, 2008 | 07:35 PM
but i have had 2 different sets, SO ITS NOT LIKE I GOT A BAD AXEL
Old Dec 1, 2008 | 06:47 AM
internetautomar's Avatar
mod or sell?
why not?
Old Dec 1, 2008 | 08:00 AM
Are the bearings OK ? That may cause vibration, which may smooth out at higher speeds ? Maybe warped rotor ?
Old Dec 1, 2008 | 08:24 AM
MaximaSpd85's Avatar
tighten the axle nut properly? are your lug nuts tight?
Old Dec 1, 2008 | 11:06 AM
7jackmack's Avatar
Bad axle(s) - specifically the inner joint sticks. Even more likely if the car is lowered.
Old Dec 1, 2008 | 04:03 PM
rxm6's Avatar
car is lowered.
both axles were replaced and bearings inspected at that time. also, pads and rotors were replaced at the same time. car does pull to the right a wee bit, but not enough to cause that shudder only at certain speeds. i will get an alignment done, but i'm waiting on new tires which are about due in a month's time. just wanted to see if there was a clear answer on this or if other member's experienced this.
Old Dec 2, 2008 | 05:44 AM
t_ahan's Avatar
same here
i have a shuttering problem to but its torque converter chatter it sounds like the same.Also ive been told that BG synthetic trans fluid can help torque converter chatter but i have never flushed it since i only have 10k miles on the fluid in there now.
Old Dec 2, 2008 | 06:24 AM
my car also pulls slightly to the right but ive had an alignment(not by goodyear,etc) but by a shop that specializes in high performance and lowered vehicles
Old Dec 2, 2008 | 07:19 AM
JtzMax's Avatar
Whatchyou say?
bad axle .... like everyone here has mentioned. I also agree that it is the inner joint on whichever axle it is (or both). Did you get your axles from Raxles? See .... if you would have, there would be none of this vibration / shuttering crap at all. Buy 'remaned' Autozone parts and see ... this is what you get. Raxles FTMFW!!!!!
Old Dec 2, 2008 | 10:30 AM
DenverMax99's Avatar
look at your hub! it is very much so possible to warp your hub which would also cause a vibration and shudder. if that is the case expect to replace your wheel bearings again soon! warped hub would be caused by someone trying to remove the main axle nut without air tools and having to pry against the lugs to counteract axle nut rotation... just a thought! also... my more realistic guess is that if your mt... you probably warped your flywheel. with a warped flywheel your car will shudder like crazy at low speeds/gears where you have enough torque for the clutch to slip on a warped flywheel. i am currently experiencing the warped flywheel problem and your description of your problem sounds very similar. i would almost bet money that its your flywheel and not a motor mount. my motor mounts made a loud thud sound when they went out and it would happen under acceleration and decceleration. with the flywheel it would make sense that you only notice it at low speeds/gears because you prob don't have the horsepower or torque to slip the clutch in anything past 2nd or 3rd gear.
Old Dec 2, 2008 | 10:38 AM
ImmaSquashYou's Avatar
seriously...i had 3 bad axles from napa. returned them one from another. went with raxles...and i almost hit myself for trying to save like $60
Old Dec 2, 2008 | 09:46 PM
JtzMax's Avatar
Whatchyou say?
First off ... welcome to the .Org mate.
Now with that out of the way, WTF are you gabbing on about? You don't seem to understand what you are talking about here. A clutch / flywheel issue is not even the topic here - so as much as you want to go on about that, it's pointless. As far as you thinking it's a hub - since when can you warp the hub so much it would cause vibration? I could see a bad wheel bearing (but that is not what the OP was asking / talking about) making noise, but not causing vibration. Not to mention that a bad wheel bearing makes a growling sound to top it all off. Perhaps you should just read more and not post just yet.
Old Dec 3, 2008 | 12:17 PM
fixerupper10's Avatar
ya its the axel like everyone said before when you have them taken off look at the berings and see if they look any different to you before you put them on.
Dont be rude! everything i've stated was out of experience in the last 3 weeks! when your wheel bearing gets bad enough your entire hub can move around up to probably 3/4" and you think that wouldn't cause a vibration? the ball bearings will overheat get mis-shapped and then start to overlap each other until there is nothing left but shards of metal inside the outer race. and no i do not think that his problem is wheel bearing related because slow speeds wouldn't make any difference. trust me on this i replaced my passenger side last saturday and my drivers side 2 weeks ago. and both had gotten bad enough to warp the hub and ruin the entire steering knuckle.(NOTE TO ALL: NEVER CONTINUE TO DRIVE ON A BAD WHEEL BEARING!)
rxm6- i've got extra axles for both right and left side. they are left over from my vlsd tranny swap. they were in perfect condition when i took them out and were purchased from the dealership 2 years ago.(6 months of which the car sat in storage) if your interested in buying them and saving some cash just shoot me a pm i'm sure we can find a price that works for us both...
jtzmax- your comment was rude! i thought we were all on here to try to help each other. all you did was repost what 10 other people had already stated... congratulations! at least i brought up a new idea and can back it with personal experience. as for you trying to call me a noob... i've been a member for over a year with this account... 2 years with my old account and i'm on here reading almost everyday. if your wondering why i don't post very often it's because i don't want to be like you and flood .org with re-stating information that is already on this site! i'm one of the few who has been respectful enough to do my research instead of reposting the same old question or replying to someone asking a question thats in the newbie forum. so i'm sorry if my idea upset you enough for you to need to call me out but maybe it's you that should calm down a little bit. if the .org is the only social life you have and you must pick your battles on here then i feel sorry for you... i'm only on here to use this priceless information from experienced vq enthusiasts. so from now on try to keep it proffesional! why am i even wasting my time writting this to you... i just stooped to your level... goodbye!
funny thing is... i used parts of your tranny write-up to put in my vlsd tranny last month. haha... small world
Old Dec 3, 2008 | 04:20 PM
rxm6's Avatar
axles are from raxles and they were professionally installed along with everything else by a very qualified nissan-only mechanic I have used for years on all of my cars
I have an at and t_ahan's torque converter chatter theory sounds interesting. I've never had my at fluid flushed or replaced for that matter and i should really check that out, which i will do tonight.
thx for comments, although, i dont understand how new axles would cause this problem? bad manufacturing?
Old Dec 5, 2008 | 09:04 AM
JtzMax's Avatar
Whatchyou say?
Denver ...
Glad my write up helped you out. That is why I am here. As for your post above .... you go on thinking what ever the F you wanna man. Your opinion means jack **** to me dude. If you think that first comment was rude, too bad I guess. I'm not on here to "shotgun" parts into a car. Your idea of the hub going bad is a bit extreme IMO. If you can't tell a bad hub (and you obviousley didn't know it untill it had gotten WAY bad) by the sound of it, you're not a mechanic. As I said before, a bad hub makes a groaning sound - most people will notice and look into the noise before it gets too bad ... but in your case, you let it go from the sounds of it.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
