Gear Whine
Old Dec 2, 2008 | 05:36 PM
Sounbwoy's Avatar
Gear Whine
I have a gear whine from my 96. It started after I had replaced the driveshafts. The pitch of the whine is not high like how straight-cut gears would sound and it seems to get louder with power application only, and seems to come mostly from the left front side. Once at cruising speed it can be heard, but it is not intrusive.
Searching around on the board seems to point to the input shaft. Are there any other reasons? Would changing the fluid make a difference?
Thanks for any input you may have.
Old Dec 2, 2008 | 06:18 PM
TLMNICK's Avatar
If you have a 95/96.....chances are you have an issues with your main input shaft bearing. Its rather common on those. I had to have mine changed once already.
Changing the fluid wont do anything....i had tried that before too. Best thing is to get it done sooner rather than later. If that bearing fully pops on you, you'll need a whole tranny.
Old Dec 2, 2008 | 07:39 PM
Sounbwoy's Avatar
Thanks. What's involved? Is it DIY job or best taken to a tranny shop? If a shop is involved, what's the cost range?
Old Dec 2, 2008 | 07:52 PM
chillin014's Avatar
it involves opening the transmission. there is a how-to somewhere on the org.
I have replaced all my bearings and I still get the whining in first gear as far as I can tell.
Old Dec 2, 2008 | 08:05 PM
EEMaxima's Avatar
My 96 has a very faint whine in 1st gear but only 1st gear. It isn't bad at all.
Old Dec 3, 2008 | 10:15 AM
whiteSE's Avatar
hehe....i had a whine in 1st, and my tranny blew up later on
Old Dec 3, 2008 | 10:17 AM
EEMaxima's Avatar
.... Uh oh. It's as smooth as butter. Should I have a look at it?
Old Dec 3, 2008 | 11:45 AM
chillin014's Avatar
I would take what people on here say with a grain of salt if I were you. I drove on bad bearings (bad IPS bearings and horrible differential bearings) for 18k before I could rebuild. And I didnt necessarily baby the thing all the time either. Its simply something you can't predict and nobody can tell you either way what is going to happen. The bearings are bad, they need to be replaced. Its as simple as that.
I think people are looking for reassurance with some things but these things are too unpredictable. Nothing is absolute.
before I rebuilt my transmission whined in all gears. If you are idling in neutral near a wall or somewhere where you can clearly hear noises your car is making (ex. fast food drive through) and you hear a noise coming from the transmission that stops when you press in the clutch..that is a clear sign of your IPS bearings being bad. If your axles have play where they enter the transmission that is a clear sign of your differential bearings being bad. But if you're going to open it you might as well replace all of them.
Old Dec 3, 2008 | 04:05 PM
Donald199's Avatar
my first gear whine too but it is only first gear
Old Dec 3, 2008 | 04:29 PM
EEMaxima's Avatar
Sounds almost like a supercharger... lol
Old Dec 3, 2008 | 06:20 PM
Sounbwoy's Avatar
This describes my issue exactly. I figured throwout was the cause of the noise that goes away when clutch is pressed in. I have some calling around to do, but still if anyone has already done this, would love to know the approx. cost.
I don't feel like putting a third transmission in this car, but it sounds like I may have to if I decide to keep the car. I'm not hard on trannies at all. I got more mileage on this tranny than the original one ( I bought the car with 65,000 on it and the tranny blew at 100,000. The car now has 295,xxx miles on it and the second transmission was bought used with 22,000 miles on it.
Hard to adapt a 5th Gen trans to the 4th Gen.??
Time for some reading.
Old Dec 6, 2008 | 01:33 PM
Buster's Avatar
Whirring and scraping (scorching) noise
I've had a whirring noise in my drivetrain for over 40k miles. I've got a '97 with a 5MT. The noise started around 100k miles and has gradually gotten louder. I still have the original clutch. It chatters once in a while, but doesn't appear to be the source of the problem. This all started before I had rebuilt axles installed, so I don't think they're to blame.
What I've read about tranny bearings seems to fit, but nobody has described exactly what I'm hearing. It whirs in all gears when accelerating with a hint of a scraping or scorching sound. I can still hear a faint combination of whirring and scraping on the highway at a steady speed. It's not quite as loud as tire noise on most roads. However, when I decelerate in any gear, the scraping or scorching sound is twice as loud as the whir. It's louder than road noise, but not annoyingly loud. The pitch of the whir changes when I accelerate in any gear, but the scorching sound is relatively the same pitch during deceleration in all gears.
Shifting and clutch action are still very good. My tranny oil level hasn't changed, but my rear seal is leaking a small amount of motor oil. I've been using a quart every 900-1000 miles for about 50k miles. I'm sure some of that is being burned off after 155k miles of engine wear.
I'm hoping one of you knows exactly what it is. It may be more than bearings, for all I know.
If I need a tranny rebuild, I'd like to know who can be trusted to do the job right in MA without soaking me.
Old Dec 7, 2008 | 10:55 PM
JtzMax's Avatar
Whatchyou say?
You would be looking for a 6th gen trans at that point (6spd). Same 5spd for 4th and 5th gen'rs. Anyway ... there are pleanty of members who have done a swap and there is a ton of info on it. I'm not sure what all is involved, as I have yet to do mine. Search and you'll get a lot of info.
As for the noise and whine ... yea, bad bearings. Not the throwout bearing though, signs of that going bad is noise and chatter when the clutch is pressed in and held. What you hear is the IPS (input shaft) bearings and from the sounds of it, probably the diff bearings as well. Nissan really screwed us on this trans by not shimming it properly from the factory. This is a common problem with our cars and as they age, it'll get more frequent. I rebuilt my 5spd (bearings only) and I did a write up on it ... in my sig. Read through it and you'll get a much clearer understanding of what it is and what's involved (for a rebuild). Hope some of this helps.
Chillin .... ya dirty bastad how are ya? You know ... you're probably not a good spokes person to be boasting that you drove as long as you did on sketchy trans bearings. LOL Not exactly Mr. Mantanience kinda talk there. hehehehe Just razzin ya a bit mate. Cheers!
Old Dec 8, 2008 | 05:35 AM
chillin014's Avatar
whats uuuuuuuup jtz. Doin good here, still enjoying the rebuilt tranny, although I must say sometimes I worry about the day that a synchro or two needs replacing.
haha yeah I drove awhile on those crappy bearings but I hated every moment of it, it hurt my self esteem lolll. I'm glad to know a rebuild is always an option, but it'd be nice to get at least an AE 01 lsd trans. BTW is your rebuild write-up still not a sticky???
Old Dec 8, 2008 | 10:44 AM
JtzMax's Avatar
Whatchyou say?
It's not a sticky, but maybe I should post it there or ask a mod to move it there. Glad all is going well for ya. I'm suprised to be honest - that your IPS seal didn't start leaking on you .... then you KNOW it's time to do something. If it gets that bad, the gear oil will get all over the friction disk and then the car doesn't move! lol Glad you got it done prior to that anyway.
I agree ... a VLSD trans would be a nice alternative alright. Wonder if they had the shimming problems the non lsd's had? Only reason I say that is due to the LSD diff bearings being different than a non-LSD. Huh .... anyone?
Old Dec 9, 2008 | 06:16 PM
modenaf1's Avatar
Haha...mine where that bad. It sounded like a flipping touring car with straight cut gears in every gear.
If I punched it in first gear, even though I have a CAI and the USIM that sounds like an army of pissed of wookies, I could hardly hear the intake over the transmission scream it was so bad haha. People would look at me funny idling in neutral at stop lights.
I am surprised with the bearings as bad as they were the transmission didn't fly apart under load.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
