Dead Fuse?
Old Dec 2, 2008 | 06:08 PM
s0mbra's Avatar
Dead Fuse?
Hey guys i have a 95 max, and my windows, and my automatic locks are not working either the circle around where you put the keys to start the car, i also just notice dat when i lock the car manually the blinking security light no longer blinks...
i think it must be a fuse that went bad, any thoughts?
thanks you
Old Dec 2, 2008 | 06:39 PM
Nopike's Avatar
If your visor lights are out its underdash fuse #40 (7.5 amp ) Upper right corner. If visor lights are OK but seats don't work check underhood fuse "f" (30 amps).
Old Dec 2, 2008 | 06:55 PM
Eyce's Avatar
are any of your window switches working? when you manually lock with any door other than the driver side on the inside, do they all lock?
Old Dec 3, 2008 | 06:33 AM
s0mbra's Avatar
No none of the windows switch works, and no when i try to lock it does't lock all four doors.
Old Dec 4, 2008 | 11:28 AM
Sabre17's Avatar
I am having the same problem also.
The list of things not working on my car is long.
The windows, locks, clock, antenna, visor lights. The alarm keeps going off when I open the door, I pulled the antitheft fuse under the hood to stop it then I have to open the trunk to disarm so I can start my car.
I read on the boards to check fuse 40 under the dash. It was a 7.5, it was blown, as soon as I replaced it, it blew.
My mechanic friend tells me its an electric short and i will need to leave the car with him the entire day for him to find it.
Old Dec 4, 2008 | 01:41 PM
Eyce's Avatar
did you check the fuses? have you tampered with any thing electrical lately?
Old Dec 4, 2008 | 07:27 PM
4thGMax's Avatar
sounds like a grounding problem
leatherneck
Sep 30, 2015 09:16 PM
conansriver
Sep 16, 2015 12:17 PM
markevans999
Sep 10, 2015 04:29 PM
jwright36
Sep 8, 2015 11:45 AM
