P0300 code, can someone help me. Im stumped
Old Dec 5, 2008 | 09:59 AM
tigersharkdude's Avatar
Alright so my car has been acting funny. When I am at a stop when in gear(D,2,etc) I can feel in my gas pedal a mis but my passengers cant feel it and when I get on it and get to a high RPM I can feel a slight miss(not bad at all). This is occasionally, it doesnt happen every time I stop or every time I get on it. My car has NGK platinum plugs w/ about 10K on them. Does any have a clue whats wrong??
::EDIT:: Fuel filter has about 6K on it
::EDIT 2:: No CEL
::EDIT 3:: Now I am getting ****** gas mpg
Old Dec 5, 2008 | 10:05 AM
IlyaK's Avatar
The Golden One
Probably something fuel related. Filter? Pump?
Old Dec 5, 2008 | 10:51 AM
pmohr's Avatar
No more Maximas...
You have a '99, correct?
Still on your original coils? If so, there's your problem.
::EDIT 2:: No CEL
So how did you get the P0300?
Old Dec 5, 2008 | 10:54 AM
IlyaK's Avatar
The Golden One
Maybe he has a pending code?
But yeah...if you're a 99 and on original coils change now lol.
Old Dec 5, 2008 | 11:03 AM
cylindar 5 is brand new, but the rest are original I guess. Changing all of the coils will be quite expensive. I got the P0300 code cause one of friends works at the dealer and scanned it for free
Old Dec 5, 2008 | 11:05 AM
IlyaK's Avatar
The Golden One
Well I suggest you take off the spark plug cover and unplug those coils one by one and see if the idle changes. Then do the same for the rear coils. This will tell you which coil is bad. However, if your problem is intermittent...I would suspect something else like a fuel pump or injector or something not giving the motor enough gas.
Old Dec 10, 2008 | 07:07 PM
BUMP FOR HELP
Old Dec 10, 2008 | 07:14 PM
vqmaxman's Avatar
Try the coils first,but If you read the chart that's posted on this thread and read all of those possible problems and figure out If any of these are causing the car to acted up. Good luck.
litch
123
Jan 4, 2024 07:01 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
