Plug in Power Steering Hose?
Old Dec 10, 2008 | 12:23 PM
EP95SE's Avatar
I did a search and couldn't find anything. What is this? And why is it in the power steering hose that leads from the reservoir to the power steering pump?
Old Dec 10, 2008 | 01:27 PM
njmaxseltd's Avatar
The power steering system load is measured and your idle speed is adjusted as power assist is required so idle speed remains stable.
Old Dec 10, 2008 | 02:49 PM
EP95SE's Avatar
um...ok....so I guess the pink plug is suppose to be there and it wouldn't be causing my power steering to fail?
Old Dec 10, 2008 | 02:54 PM
pmohr's Avatar
No more Maximas...
It's in the suction line between the reservoir and the pump?
Old Dec 10, 2008 | 04:13 PM
EP95SE's Avatar
Yep. There are two large diameter hoses that connect to the PS pump. The pink plug was in the hose without the copper fitting. I pulled the hose without the copper fitting off the power steering pump and the pink plug came out along with the excess power steering fluid.
Is it suppose to be in the hose?
Old Dec 10, 2008 | 10:07 PM
EP95SE's Avatar
Was hoping to put the power steering back together tomorrow. Anyone else have any other thoughts?
Old Dec 11, 2008 | 01:30 AM
pmohr's Avatar
No more Maximas...
Is it hollow in the center, or is it an actual plug?
From what I can tell in FAST, there isn't supposed to be anything in or around the suction line, just the line itself and the two hose clamps.
Old Dec 11, 2008 | 05:27 AM
njmaxseltd's Avatar
Plug as in end cap? Possibly put on the hose to keep contamination out during assy?
Old Dec 11, 2008 | 04:01 PM
EP95SE's Avatar
It's not hollow in the center. It's an actual plug.
It's not an end cap either because the diameter of the plug is slightly less than the hose and the plug was found inside the hose.
So it looks like it's not suppose to be in there. I'll leave it out when reconncecting the hose to the ps pump.
Here's what I think happened. The power steering stopped working right after a shop helped me remove the old water pump. So I'm thinking that they drained the reservoir by disconnecting the hose from the reservoir, and then plugged the hose to keep contamination out of the hose. When they reconnected the hose to the reservoir, they forgot to take the plug out.
Old Dec 11, 2008 | 04:04 PM
pmohr's Avatar
No more Maximas...
Yea, there's no way in hell the suction hose should be completely stopped off. Did you drive around with the car like that? If you starved the pump of fluid, could've caused some damage.
I'd highly suggest taking pictures of the hose on the pump, then the hose pulled off with the cap in it, and the cap, etc and show them to the shop. If you have any issues with your PS pump in the near future, I'd go straight back to them to have them fix it on their dime.
Old Dec 12, 2008 | 07:13 AM
njmaxseltd's Avatar
Old Dec 12, 2008 | 03:40 PM
EP95SE's Avatar
Good idea on the pictures. Yeah the power steering pump has been out ever since the shop returned the car to me. I'm in the middle of replacing the power steering pump which is how I found the plug.
Thanks to everyones feedback and ideas.
Old Dec 13, 2008 | 08:16 AM
ThurzNite's Avatar
This's interesting, I'm subbing to see the pics.
Old Dec 13, 2008 | 08:17 AM
ThurzNite's Avatar
Do you think it could be an access hole to perform a PS fluid flush?
Old Dec 18, 2008 | 09:03 AM
EP95SE's Avatar
Here is a picture looking at the power steering pump from underneath the car showing how I found the plug in the power steering hose.
lowpost99
Oct 26, 2025 06:53 PM
9aj9
Apr 5, 2020 12:11 AM
aminus21
Sep 12, 2015 04:53 PM
dcam0326
Sep 7, 2015 07:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
