97 MAXIMA IAT?????
Old Dec 21, 2008 | 01:08 PM
fishforlife2007's Avatar
97 MAXIMA IAT?????
ok here it is.... i just installed a new intake system that a got one heck of a deal on. its an injen intake, and most everything went as planned on the install. there is one issue. on my stock air intake there was the sensor for the IAT, but there was no port on the injen cai for such sensor. i installed and started vehicle and now my check engine light is on. is this just something that can be fixed by drilling a hole in the cai and installing the sensor in? im not too familiar with the sensor, but i believe that it just measures the intake temp. i just though that i would get a second opinion before i drill a hole in my cai piping. oh yea, if it is ok to so, is there any specific location that i need to place this sensor? would assume somewhere before the MAF....any advice or suggestions would be much appreciated. thanks.
Old Dec 21, 2008 | 01:28 PM
djipka's Avatar
you may be able to get rid of the code by simply getting the sensor off of the snorkle and plugging it in the harness. even if it just hangs (which I personally couldn't live with) it might take care if the CEL
Old Dec 21, 2008 | 01:31 PM
I just put mine in the filter itself. No CEL for me.
Old Dec 21, 2008 | 01:33 PM
in the filter?????do you have a pic of that???im def. not gunna just let it hang... would it be ok to drill and put it in the piping
Old Dec 21, 2008 | 01:51 PM
Yes in the filter. I don't have an Injen though. All you do is put the sensor in the filter, and pop the filter back on. If you don't wanna do that then I guess you can drill a hole in the piping, but why go through all that trouble?
Old Dec 21, 2008 | 08:36 PM
hornepirate's Avatar
plug the damn thing in and zip tie it something...i bet you $20 the code will go away and the car will act normal
Old Dec 21, 2008 | 08:56 PM
Snypa's Avatar
this sensor hardly does anything important. But just for the non-tacky look, if u can, bore a hole and snuggle it down in there.
Old Dec 21, 2008 | 09:03 PM
djipka's Avatar
I vote for the zip tie to something so it's plugged and out of the way.
Old Dec 25, 2008 | 02:25 PM
i ended up just drilling a hole in the cai, and putting the grommet and sensor in like that..ended up looking somewhat ligit.. thanks for the advice
Old Dec 25, 2008 | 02:30 PM
Good job.
Old Dec 25, 2008 | 03:22 PM
Eyce's Avatar
i drilled a hole in the filter itself on the plastic base for the sensor, then reset the ecu and the CEL went away
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
