Need help code p0302
Old Dec 27, 2008 | 05:20 PM
maximus_pr's Avatar
Recently check codes cause car was misfiring and code P0302 came up, so the followinf things were done on the car
change spark plugs
change fuel filter
switch coil between coil 2 and 1 reset ecu code p0302 same code came up after 5 minutes run car still misfiring
move back the coils and the switch between coil 2 and 3 reset ecu and same code came up after 5 minute run car still misfiring
so far all i can think of is either the #2 injector is bad or maybe fuel pump but to my understanding if fuel pump was bad it misfires and probably all cylinders shows as misfiring
take in consideration this car was taken to 4 different places and all of them have different opinions from bad spark plugs wires(spark plugs wires omg ) to a bad engine that was offered to repair for $3000(yeah right just wait there, i be back)
I'm pretty sure is a bad injector just wanted your opinions
Old Dec 27, 2008 | 05:37 PM
maxfever1987's Avatar
since u stated u change between coil 1 and 2 and still same code 5 mins later, 100% its ur injector cuz a bad fule pump wouldnt just show 1 injector going bad, my suggestion try the ez way first replace injector 2 and go from there.
Old Dec 27, 2008 | 05:38 PM
maximus_pr's Avatar
just what i though
Old Dec 27, 2008 | 06:25 PM
pmohr's Avatar
No more Maximas...
How exactly did you swap coils from cylinders 1 and 2? Completely different style and size of coils.
Did you test the injector? Don't replace it before you test, that's just an idiotic way of throwing parts at the problem.
Old Dec 27, 2008 | 08:06 PM
maximus_pr's Avatar
coils were switched between the one the middle and the ones on the sides i didn't do it personally cause this is my ex-wife's car who live in Ohio I'm in Florida,so i was trying to figure out what is wrong that way, i told her to take car to a mechanic but since none of the idiots seems to give a trustworthy diagnose i told a friend to do all the things mentioned above but he tried to "hear" the injector but could not distinguish if is working or not and since most everything else is done what else could be?
and maybe is and idiotic way to throw parts at the problem but sure is better than replacing the plug wires
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
