Rear brakes stick after using e-brake
Old Jan 12, 2009 | 12:51 PM
ThreePointO's Avatar
About 6 months ago i changed my rear pads and rotors. Ever since i changed them Ive been having a problem with the e-brake. It works correctly but after i take it off and begin to drive there is a really bad smell after about 3 minutes, it smells like burning brake pads. I don't feel any resistance but it definitely smells like burning brake pads to me. If i park my car for a few hours and then drive it again its gone. I haven't used my e-brake for a long time because of that issue, but i put it on the other day just to see if the problem persisted and the same thing happened.
Any ideas about what could be wrong?
Old Jan 12, 2009 | 12:52 PM
mtrai760's Avatar
'Trynna' is not a word
Broken return spring on the calipers, or corrosion causing the cable to stick.
Old Jan 12, 2009 | 01:07 PM
pmohr's Avatar
No more Maximas...
The cables tend to be damaged where they follow the trailing arms by improper lifting, if water or debris enters the sheath it can cause the cables to stick up.
Old Jan 12, 2009 | 01:47 PM
lilaclucymaxima's Avatar
Team Ramrod
You've got to be kidding me. Stop being lazy and look around. There's a thread like this on the SAME PAGE. http://forums.maxima.org/4th-generat...ease-help.html
Old Jan 12, 2009 | 03:59 PM
well my e-brake doesnt stick enough so i can feel it, and it was during warm weather. i thought it may be a different problem. but thanks for pointing me in the direction of some more knowledge concerning an issue like mine!
Old Jan 12, 2009 | 04:05 PM
So its possible there's some stuff in/ around the e-brake cable which doesn't allow the brake to release entirely. Ill check it out again, i looked around when it first happened, but didn't see any debris. Luckily i have an automatic so i usually dont use the emergency brake, but its nice to know i can.
Old Jan 12, 2009 | 06:10 PM
heynow's Avatar
Have a trusted shop take apart & lube the rear brake hardware.
I just did that two weeks ago. BEEEEEAAUUUTIFUUL!
Old Jan 12, 2009 | 06:53 PM
yea... ill put it on the list.
Old Jan 12, 2009 | 08:07 PM
Team Ramrod
Sorry, I didn't mean to jump to conclusions and get angry. The bracket that connects it to your rear calipers can still be corroded even though you aren't in cold weather. It also could be your rear calipers.
Old Jan 13, 2009 | 07:41 AM
i had a problem getting the pads back in when i was replacing them. if i remember correctly i had to take the caliper off and screw? something back in. I had that problem on both sides.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
Lowered_a33
Aug 24, 2015 04:35 AM
egali045
Aug 16, 2015 01:19 PM
