Question about Check Engine light.
Old Jan 13, 2009 | 10:08 PM
Dany's Avatar
Hello,
On my 99 Maxima GXE I recently got Check Engine light and went to service to get it checked out, turns out they got two error codes from this:
1. O2 sensor
2. #5 ignition coil is generating miss-fire.
Question I have, I know that O2 sensor causes Check Engine light to come on, but does failed ignition coil cause Check Engine light as well?
Thanks a lot
Old Jan 13, 2009 | 10:18 PM
pmohr's Avatar
No more Maximas...
What exactly is the code? P0305? That code just points to a cylinder misfire, not specifically the coil.
But yes, every DTC other than 0304/P0325 will light the CEL.
FWIW you can check the codes yourself for free quite easily, so I hope you didn't pay them to check the codes for you.
Old Jan 13, 2009 | 11:22 PM
FallenOne's Avatar
Phmor would be correct. Not that it was ever a question...
Hey, Use The Search Function Buddy
Yeahhh sure good to have some conversation once in while.. Especailly at Midnight! But Hey you've been here long enought to know the drill.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
