ecu screw broke now car wont start
Old Jan 19, 2009 | 12:34 PM
Ice7386's Avatar
hey i have a 99 maxima and i was trying to reset my ecu but when i poked the sticker i accidently pushed to hard and the whole screw driver went into the hole and it shut my check engine light off but now the car wont start. The engine cracks but wont start. Is there anyway to simply fix this or am i gonna have to get it towed to a mechanic?
Old Jan 19, 2009 | 01:03 PM
pmohr's Avatar
No more Maximas...
Pull the ECU, yank the cover off and see if you managed to destroy anything on the board.
Old Jan 19, 2009 | 01:10 PM
Ice7386's Avatar
how do i know if i messed up anything on the board and how do i pull out the entire ecu...i havent done this before thanks
Old Jan 19, 2009 | 01:18 PM
pmohr's Avatar
No more Maximas...
Well, you look at it for any missing components, a big scratch across some traces, etc.
Easiest way I've found is to pull out the radio/climate control, pull of the black plastic shroud directly in front of the ECU that directs air, then you can get to the 2 10mm head bolts that hold down the ECU bracket. From there, unplug the 2 or 3 harness connections that branch off into the dash, and work the ECU/bracket/harness out from underneath the dash.
Takes ~15 minutes on a 5MT, a bit longer on a 4AT because of the more limited space.
Old Jan 19, 2009 | 01:41 PM
Ice7386's Avatar
theres no scratches or missing components and my car started fine right before i tried to reset the ecu, i just poked my screw driver a little to far deep in there and i dont know what kind of damage that causes but i really dont know how to get it to work normally again
Old Jan 19, 2009 | 01:42 PM
pmohr's Avatar
No more Maximas...
So you pulled it? What does the diagnostic screw look like? Is it completely destroyed, or was it just pushed backwards?
That's why you don't just stab a screwdriver through the plastic, you either cut it or peel the sticker back.
Old Jan 19, 2009 | 01:44 PM
djipka's Avatar
when I replaced my ECU it took forever. I took it out from the side though. there are 4 small screws that hold it to the bracket. The one I installed came off of a junked car so I tore my way through to get it out. I did that the way pmohr has suggested and I bent the bracket doing it. so be careful either way you decide to go about doing it. The 4 small screws are quite e PITA to undo. I used 3 different screwdrivers to get to them and undo them.
Old Jan 19, 2009 | 01:46 PM
pmohr's Avatar
No more Maximas...
Yea, those 4 screws are a complete PITA to get to in the car, first time I pulled my ECU that's how I tried to do it. An hour later, I said screw it and pulled the bracket, harness, and ECU all together. 15 minutes later I was done.
Old Jan 19, 2009 | 01:50 PM
Ice7386's Avatar
no i still havent pulled it out but if i do can i re attach the screw and have it working normally again or am i going to have to replace the whole thing?
Matt93SE's Avatar
STFU n00b!
The 'screw' inside the ECU is actually a potentiometer. it's very likely you either shorted the traces on it with the screwdriver OR you broke the pot off the circuit board. It's probably repairable, BUT you'd have to be able to repair electronics to do it.
For the time and efforts, your best bet is to buy another ECU from a junkyard or whatever and just toss the old one.
Old Jan 19, 2009 | 01:51 PM
pmohr's Avatar
No more Maximas...
So how do you know you didn't scratch the board or damage anything?
In any case, that's exactly why you should pull it, to determine what's broken, if anything.
Old Jan 19, 2009 | 01:52 PM
TLMNICK's Avatar
Chances are you poked something you shouldnt have with the screwdriver when you shoved it through the plastic cover.
It was only a little piece of tape...a light poke would've done well.
it being a 99 too, you'll have a transponder key, which means that your ECU swap wont be simple (if it comes to that)
Old Jan 19, 2009 | 01:53 PM
Ice7386's Avatar
ok but is it normal for my car not to start and when i pull it out is it repairable?
Old Jan 19, 2009 | 01:55 PM
pmohr's Avatar
No more Maximas...
If you damaged the board, yes.
Jesus. That's why you're pulling it out, to DETERMINE that.
Old Jan 19, 2009 | 01:59 PM
Ice7386's Avatar
ok its actually snowing pretty bad in jersey so im probably going to pull it out when the weather clears and ill post the condition of the ecu when i get it out
Lakersallday24
Jun 16, 2019 01:35 AM
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
maximaham
Aug 7, 2015 01:11 PM
