Check Engine, TCS and Slip Lights On...
Old Nov 15, 2001 | 01:40 PM
stefnee's Avatar
I have a 99 SE-L that before 30,000 miles, the check engine, TCS and Slip light came one. Took it to Herb Gordon and they said a sensor went bad. At 36,000 the same lights came back on. Herb Gordon said the engine harness needed to be replaced, then came back and said Nissan service suggested they check the engine coils first. They replaced six engine coils, everything covered under warranty thankfully. So today I'm at 38 and some change, and the lights came back on. Has this happened to anyone else, if so what was done to correct it?
Hubby wants to drive it on someones lot so he can get the 2002 Maxima and let give me his "Hand me Down" 01 20th AE!!!!!
Stefnee
Old Nov 15, 2001 | 01:57 PM
DhaMax's Avatar
have you checked the error codes from the ecu yourself? If not try it and see what error codes the ECU shows, and then take it to the mechanic. You can search on the forum on how to check the codes, and i believe there is a sticky on how to perform the test. good luck
Old Nov 15, 2001 | 02:19 PM
stefnee's Avatar
Just Printed them out
I went looking for the codes and found them. Will do some checking tonight before I drop it off tomorrow.
Stefnee
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
