Brake lines rusting badly.
Hi all, the other day I was under the car looking for the culprit of my exhaust rattle that I have at certain RPMs (still looking), when I noticed my brake lines at rear of the car were very badly rusted. The rust was even flaky in some sections. Question, for those who live in the rust belt, has anyone tried to replace the long steel brake lines on their 4th gen Max? If yes, what was your experience and issues, and where did you purchase the lines. The brake lines I'm talking about are those that run from the master cylinder to the rubber brake line at the wheels.
Thanks,
Thanks,
As for the rattle, I'd look for loose heat shields (i.e. missing/broken fasteners). I also saw the ring on a flex joint holding the protective metal braiding at the ends come loose once.
i would just cut off the pieces that are bad and flare good pieces on there. Trying to replace the full length of the lines will be pretty PITA. Tried it on the 3rd gen, i still have the oem lines sitting at my house. Winded up just splicing and putting new lines where i needed.
http://www.ehow.com/video_2328133_to...ake-lines.html
that is a very good video tutorial. I would rent the flare tool and tube bender. You will need the tube cutter which is like $6. And a bunch of different lines and u joints. Flaring the tube yourself is not as hard, took me about 3 times to get it right and then i was doing it perfectly.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
