Pulley questions...
Hello there,
Just this past weekend I was replacing my A/C belt and I realized the common crack in the rubber around the crank pulley. So I need to replace the pulley and to be honest I would prefer to go with an aftermarket pulley but I dont like the idea of underdriving my car. So what I want is just an aluminum lightweight stock size pulley. The thing is though the only one I can find is the $240 unorthodox pulley. Me personally I dont want to spend that crazy amount of money on a simple pulley. Maybe if it was a complete set I'd jump right on it but for one pulley thats a bit high in price for me personally. So here is where I need your help... I have been looking around for other crank pulleys that are not under drive just lightweight pulleys for a 1996 Nissan Maxima with the VQ30DE engine. Like I have said the only one I can find thus far is the unorthodox one, However while searching I have seen some stock size lightweight aluminum pulleys for the VQ35DE maximas so what I am wondering is would the crank pulley from a VQ35DE maxima fit on a VQ30DE maxima engine? Also while I am at it I might as well ask if the pulley set for the VQ35DE 350z's will also fit onto the VQ30DE? If anyone has any idea about the answers to any of these questions and would not mind informing me it would be greatly appreciated. I have searched and I am thinking from what I have read thus far it will work but I have not found a definite answer yet. Thanks Stephen |
This is not an all-motor worthy topic.
You must use a VQ30 crank pully if you're using a VQ30 ECU. Simple as that. A VQ35 pulley will fit but it won't have the "teeth" that the VQ30 CPS (REF) is looking for. |
Originally Posted by nismology
(Post 6878723)
Originally Posted by Blackmax1924
(Post 6878739)
I apologize next time I will post a thread about some guy trying to lie to people about his dyno numbers to make his car seem faster than it really is, cuz thats more of an all motor topic...... THANKS!!!
Maybe I should have locked this one outright instead of actually providing a helpful answer. :idea: |
If it's any help, just for comparison I had to replace my crankpulley/harmonic balancer (that's what that black rubber is I was told) and could only find one through a nissan dealer for $250. That was a few years back, but consider paying that amount for a OEM pulley. Have a great day!!
well replace it soon. the rubber that holds it togather seperated on my car, throwing the alt. belt, and the only reason my car was running was 2 ribs of the power steering belt that hadnt been eaten away by the pulley moving in. it was FUN trying to get that bolt off...... anyways have you price checked that stock crank pulley....they aint exactly cheap my friend.
(Post 6878750)
It involved a very complicated swap into a chassis that was never meant to accept such a large motor, but thanks for playing.
Originally Posted by WhiteMaxima9600
(Post 6878800)
Originally Posted by fishforlife2007
(Post 6878875)
Thanks for the help! |
My crank pulley separated from the harmonic balancer today, threw the belts and ruined my day. I need a new one, but don't want to spend a lot of money. Has anyone used OBX stuff before? They're like 75 bucks after shipping on ebay, much cheaper than oem.
I've removed and reinstalled the crank pulley on my mustang several times (not to mention the engine); so I have some experience with this type of repair. How easy is it to do on a 96 Maxima? Do I need anything special, other than the pulley tool? How accessible is the front main seal when the crank pulley is off.? If it's a quick fix I'll replace that at the same time. thanks |
Originally Posted by Max95Max
(Post 7025496)
I've removed and reinstalled the crank pulley on my mustang several times (not to mention the engine); so I have some experience with this type of repair. How easy is it to do on a 96 Maxima? Do I need anything special, other than the pulley tool? How accessible is the front main seal when the crank pulley is off.? If it's a quick fix I'll replace that at the same time. thanks The front seal is right there behind the pulley. They never really leak. If yours isn't leaking, don't replace it; no reason to replace a perfectly working seal for no reason. I'd just go with a used crank pulley. The UDP doesn't gain you virtually anything, and IMO it's got a lot more potential to cause problems. |
Thanks for the reply, I won't replace the seal if it's not leaking, but I think it is. I'll have to really look at it when I get in there.
I don't want a udp, I just want a cheap stock-size replacement, but I can't find a used one near me on car-part. com Will a pulley from a 1995 up through 1999 fit? |
(Post 7025539)
I don't want a udp, I just want a cheap stock-size replacement, but I can't find a used one near me on car-part. com Will a pulley from a 1995 up through 1999 fit? There are several part outs in the classifieds right now. Or check with Maxima_Joe. |
© 2024 MH Sub I, LLC dba Internet Brands
