5-speed transmission replacement question
Old Feb 23, 2009 | 01:35 PM
fellfrosch7's Avatar
I need to replace the tranny in my 99 SE 5-speed, and want to know specifically if it makes a difference if the new tranny came from an ABS or non-ABS car. Mine doesn't have ABS, and no limited slip (obviously).
I tried searching, but "ABS" is too short and I get nowhere.
Old Feb 23, 2009 | 02:21 PM
Bobo's Avatar
I fail to see what ABS brakes have to do with a manual transmission.
Old Feb 23, 2009 | 03:24 PM
dgeesaman's Avatar
Maintenance Monster
No difference in the transmissions.
Dave
Old Feb 23, 2009 | 05:22 PM
pmohr's Avatar
No more Maximas...
No difference at all. If you're looking for a bit of an upgrade, look for a VLSD trans and axle.
Old Feb 23, 2009 | 08:52 PM
When I bought axles a while back, they asked me if my car had ABS or not. I thought it was just for the axle clip or something, but I thought I'd ask just in case. So any 95-99 5-speed will work fine, right?
Old Feb 23, 2009 | 08:57 PM
Blackwind's Avatar
yes. if you need help give me a shout
Old Feb 24, 2009 | 12:01 PM
QNO_A32's Avatar
they ask because if the car has abs there will be a ring near the outer joint right where it goes into the hub for the sensor to read off.
Old Feb 24, 2009 | 03:31 PM
pmohr's Avatar
No more Maximas...
If your car doesn't have ABS, you can use either. If your car does have ABS, you can use either, but only the ABS axle will keep the system operational.
CorollaULEV
30
Aug 9, 2021 08:11 PM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
niZ
Aug 7, 2015 10:18 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
