Auto vs Manual HP?
Auto vs Manual HP?
** Please hold back the flames as I'm sure its being asked before but I can't find it **
What is the HP difference to the ground between STOCK 4Gen-Auto vs 4Gen-5Speed?
ie Is there significant power loss with an automatic compared with manual?
10-15whp sounds reasosnable figure to me
Yeah, I'm starting to wonder if anyone can read on these forums. He asked a perfectly valid question that I have wondered about myself.
No 5 spd Maxima is going to put down more HP than a 6 spd maxima (3.0 vs 3.5 engine).
However, if we're simply comparing transmissions, i.e. same engine mated with a 5spd vs a 6 spd, then in theory this assumption would be correct, however, the difference would be so small that other factors would greatly overwhelm it, and the gearing advantage of a 6 spd would make up for any efficiency loss.
Don't quote me on this, I don't have any research to back it up, just driving experience. I don't believe there is a significant difference between the two.
The manual should feel as if it is putting out more power, simply because the driver is able to reach higher rpm's which makes the engine work harder.
Yes, you can reach the same rpm's, but you cannot maintain the higher rpm's in an automatic, unless I'm mistaken. Also, automatics will not allow you to down shift to reach higher rpms in a lower gear.
Yes, automatics will downshift as far as possible when WOT, and you can maintain the RPMs as long as you'd like, if you change the position of the shifter.
my03maxima
Jul 28, 2024 07:40 AM
tarun900
19
Dec 20, 2021 06:57 PM
It's ok though, it needs stated for any noobs that may read it. I appreciate the answer, however
