300zx Calipers
300zx Calipers
I've found some aluminum 300zx calipers for a good price. I havent picked them up yet, because I dont recall all the "extra" parts I'll need. I recall you have to mill down the rotors a certain amount. And I've come upon some post saying something about "brackets", what brackets are we talking about Jeff92se's? Do I need them? Do i neccesarily need cobra rotors? Or are these just bigger rotors?? I've searched but nothing really comes up, except for Q45 calipers, 300zx rims, nothing really that answers my questions.
Thank you
Thank you
So you say you searched?
http://mattblehm.com/brakes.htm
http://forums.maxima.org/advanced-su...n-z32-bbk.html
http://forums.maxima.org/advanced-su...ion-links.html
http://forums.maxima.org/4th-generat...e-upgrade.html
http://forums.maxima.org/general-max...ale-again.html
http://forums.maxima.org/4th-generat...zx-brakes.html
And so on.
All but one of those links is from the stickies, you didn't even have to search.
Use his calipers and the rotors to go with them, the rotors will need to be milled down 2-4mm of there diameter.
You will also need to cut the dust sheild off, and grind down the control ar a bit.
You will also need conversion lines, but you could try the 300z lines if you have access to them. Im not sure if they will work or not but the majority of people using the Z32 calipers use conversion lines.
And so on.
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
