maxima running rough according to startup?
Old Mar 17, 2009 | 08:53 AM
ne max's Avatar
My '98 Max (101k miles) has been intermittently running rough vs. smooth after startup:
1) Once i've started it up, it will run either rough or smooth until i turn off the car - but it never changes from one to another after it's been start up. If I start it up again at another time, it will again either run rough or smooth (it may change with each startup).
2) If the max is having one of it's "rough" runs, I notice that it tends to want to "push foward" when releasing the brake from a stop (without pressing the gas), and also I need to be more aware while braking because it's like the engine wants to keep pushing the car foward. On "smooth" runs, max feels like a regular car - stopping smoothly and easily, and moves foward "gently" after releasing the brake from a stop.
3) Some other driving characteristics - on "rough" runs, max feels rougher over rough roads, and pushes more on turns like it has more understeer. On "smooth" runs, max runs beautifully - it's smoother on rough roads and turns easier.
4) Idle seems fine to me during either situation. Idle is ~650.
Incidently, there has been a loud squeal with startup, worse on cold mornings, and i'm pretty sure it's coming from the starter - don't know if this would have any bearing on what's going on? I do know that the presence of the squeal is not associated with whether the max will have a "rough" or "smooth" run.
Also, scanner has shown diagnostic trouble codes.
I know this all may sound crazy, but this has been going on for a several months now, so I've had enough time to pay attention to the max's behavior. Anyone have any ideas ??
Old Mar 17, 2009 | 09:00 AM
pmohr's Avatar
No more Maximas...
And you didn't see fit to include said codes?
That's obviously the first place to start...
And for the squealing on startup, have you not checked the belt tension?
Old Mar 18, 2009 | 06:19 AM
ne max's Avatar
Sorry, i meant the scanner DID NOT show any codes.
Belt tension appears to be fine.
Old Mar 18, 2009 | 06:32 AM
njmaxseltd's Avatar
Why did you make two posts about this?
You already have responses in the general section.
Old Mar 18, 2009 | 08:47 AM
ne max's Avatar
Sorry, someone recommended that I post my question in the 4th gen forum.
dank4us
34
Jun 10, 2024 03:45 AM
LilVito
Oct 25, 2019 08:12 AM
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
09maxshawn11
Aug 9, 2015 01:13 PM
