Brembo Brakes
Brembo Brakes
I just recieved my brembo blanks from autobarn but one rotor has two dimples mahcined into the rotor where the pads would be making contact. I tried to contact them but I think they close at 6pm. Their number give a busy signal. Anyone ever seen anything like this? Makes me doubt they are real brembo blanks.
It's most likely just fine, but if you're concerned, why not have them exchange it?
i saw on autobarn that there are two differnt size rotors?
part #25314-Front Brake Rotor;Front ; to 3/99 ; Min Thick-Max Dia 20mm; Years: 1999-1999;Qty Per Vehicle:2;
part# 25575-Front Brake Rotor;Front ; From 4/99 ; Min Thick-Max Dia 24mm; Years: 1999-1999;Qty Per Vehicle:2
what cars are different? i have not pulled my rotors off mine yet to actually find out.
What pads are you gonna be running with the brembos?
Anyway, 25314 is for the '99 model year, 25575 is for the '00 model year.
'99 model years weren't produced past March of '99.
In the package the blanks should have a paper explaining that the dimples are wear indicators. One is deeper than the other. If you can only see one it is time to replace your rotors. If you can't see either, you're screwed...
This is the weird rotor:
See how the rotors don't have the same stampings? The weird one has only one stamping while the good rotor has a lot more info stamped on it and also has the brembo logo stamped onto it.
That dimple is most liklely there to indicate when the rotors have reached there limits of wear.
Essentially, when the dimple is no longer visable, the rotor must be disposed of, as it cannot be machined anymore and needs to be replaced.
I know my brembo rotors had brembo stamped on the outside.
So why does one rotor look different than the other. One has the dimples and doesn't say brembo while the other one that says brembo doesn't have the dimples. Should I just use them?
I called brembo at 17347375823 and I was told that the "easy check" rotors have "notches" so that you can check when the rotor is worn out. This is the stupidest thing I have ever heard. That's what micrometers are for. I was also told that depending on where the rotors are made they may or may not be stamped with brembo on the side.
I hope these are better than the cheap rotors at parts stores because it doesn't sound like it. Can't wait till next week to put it all on. Thanks everyone for your help.
Can you use measure the rotor with a micrometer while the wheel is on?
If you answer NO to any of the above, then the easy check isn't so stupid.
It allows you to monitor the rotors condition accurately, by eye.
Sounds like a pretty dam good idea to me.
Yes and yes, so thanks for allowing me to call it stupid. It's not stupid I was just frustrated with getting two different rotors and having to wait to install them.
Do you own a micrometer?
just to note, the reason i got rid of mine is because they rust like a ***** - and quickly at that.
i would suggest painting them or giving them some sort of enamel covering to prevent rust, otherwise you are going to have brown rotors in about a week.
Should I return the non-dimpled rotor for a dimpled one?
When I ordered them I didn't even know the dimpled (easy-check) rotors existed.
The oem ones rust as well don't they? I have flat black paint but it's not high temp so I don't think I should spray them with that. The rust won't make the rotor work worse than if it were painted? Should I really paint them? If so I will go out and buy high temp paint.
OP. I have some new Brembo blanks sitting in Brembo boxes awaiting install for my other Max. I can check to see what I have if it will make you feel any better and for comparison sakes, although it sounds like others have answered your questions/concerns already. Let me know.
If you can check on the stampings along the edge of the blanks that would be great, thanks! I'm going to measure the rotors thickness and if everything is well I think I'll keep them both. How's the brake setup in the pic?
Close, but not quit. I have the "upgraded" Brembo GT kit.... 2 piece 13.1" rotors....4 pot calipers....the whole shebang.
I run mine with Hawk HPS pads and Stainless Steel braided lines for some decent stopping power on stock calipers. Havn't had any issues other than aestetics yet
The Brembo BBK is great. No fade ever, awesome stopping power etc.
I have Brembo blanks in the rear (cross drilled) and they're still gold where the pad doesn't touch...
I have the Brembo cross drilled and eventually the nice gold plated look will start to wear off. Im going to be repainting my calipers and the ring around where the hub is. Easy to do just time consuming.
Freakin' awesome. Love em. I have a nice even two finger gap all the way around. Can't slam it with the CF body kit.
Brembo DOES NOT do this. The only real brembos you will find will be really really gold in color, Be slanted or crossdrilled and trust me. No one on Maxima.org in group sales has the real ones. They are mostly all fakes(I bought them trust me) Or they are Brembo blanks that have been pressed with their own milling machine. I even got into an argument with the guy from group deals that sold me them and he wouldn't even answer me when I asked him if he drilled slotted them because they were done poorly. A company like Brembo would never do them poorly if they are real. Also I know I got fake ones because the price was cheap at the time AND they are rotting now. A year and a half later. Avoid them at all costs. Unless you buy from Brembo or a certified Brembo dealer.
There is not a single brembo in the world that is drilled/dimpled/slotted.
Weird. Over a year later, my are still as mint and gold as the day I installed them.
I had mine over two years and they are not as gold as before.. No rust or anything though.
Here's what stamped on them. 30 05D RR "Brembo logo" MIN TH 20mm 526 09.5254.10
I wouldn't. I'd use the paint specially made for calipers/rotors sold at Autozone etc. I would image that rotors get pretty darn hot. Plus, regular flat paint probably won't up very well against the elements ie weather, debris etc.
When you're done, don't forget to clear coat it.
Progress Gen III Maxima specific coilovers
